Connecting 4" Cast Iron with 3" PVC
Molo
Cold New York
Hello,
I have a vertical 4" Cast Iron piece that I want to connect a horizontal 3" PVC drain to. The local store has a "saddle" with a gasket on the inside and u-bolts that will wrap around the CI. The connection will be at approximately a 90 degree angle. So, the material in the PVC drain will travel horizontally at 1/4"/ft. and then drop down into the CI. Is this a common and good way to make this connection?
Thanks,
Bill
I'm not a plumber, but if I had to do this, I'd probably cut out a section, then insert a wye using no-hub connectors. Now, there may be an issue with putting pvc in the middle of the run because of the weight. If the pipes are properly braced, that shouldn't be a problem. But, you could put in a CI hubless wye, then convert to pvc, and all would be well.
Gary Swart
Yakima, WA
Just because a store sells it, doesn't make it legal. They still sell S traps at Ace Hardware.
Tom Sawyer
Maine
They sell S traps because it's legal to repair or replace and existing one. Now if you want to talk about the plastic accordion tail stocks LOL
1. It is an illegal connection. ALL plumbing codes prohibit "saddle connections" except for connections to the main sewer in the street.
2. It is also a bad connection function wise.
3. Cutting a 3" round hole in a 4" cast iron riser will be a very time, and tool, consuming process.
Molo
Cold New York
Thanks for the reply,
What is a code compliant method for this?
Molo
Cold New York
Yes, those connectors are what is required. The riser clamps may require opening the wall above. If it goes through the middle of a stud bay, you can just install it using the floor as the support, otherwise, you have to get creative. A tall stack of CI can weigh hundreds of pounds. Now, the horizontal offshoots may support it, but it also could sag considering lead is maleable...so, it needs to be supported BEFORE you cut anything. Convert to pvc at the outlet of the wye using another nohub connector.
Word of warning, the snap cutter usually makes a fairly decent cut, but if the pipe is particularly old and maybe thin, it can shatter. If the tool is well used, the cutter teeth may be a little dull, making a nice cut harder. It literally squeezes the pipe with what looks sort of like an oversized bike chain with round beveled disks placed around it. Those come to a point and when tightened, produce immense pressure which, once you get it tight enough, will crack the pipe at that point. Once you have the section cut out, you may need to grind things to get the edges smoother, but if you're lucky, you won't. Depending on the tool, you may need to be careful keeping the chain nice and straight until it gets tight...the straighter you start out with, the cleaner the cut. They usually don't have a huge amount of side-to-side play, but again, when old they get stretched, and it can make a difference.
I've rented one at HD a couple of times. They don't tend to get a lot of use, and the ones I've gotten were nearly new. Your results may differ! From start to finish, a cut only takes a couple of minutes once you figure out how it goes together (it's pretty simple). So, often, you only need an hour or two for the rental depending on how far away it is.
Molo
Cold New York
Thanks again Jad,
I'm leaning toward a CI wye because of the weight. I'll have to see if the local supply houses have them. Either way I will be clamping and bracing the CI riser.
You may want a no-hub sanitary tee rather than a "Y". In almost EVERY case the piping connected to the cast iron in the wall, and at the toilet will support it without any additional bracketing. I have cut into many cast iron risers and have never used riser clamps on any of them. IF the pipe went directly from the basement to the roof, without any connections, it MIGHT need a support, but even then the "hubs" would probably support it from a top or bottom plate. But you would not need a 4" riser if there were no connections to it.
Molo
Cold New York
Thanks for the input HJ. Do you think that a PVC san-tee would work, or should I be using a CI san-tee?
Thanks
Either one, but a cast iron one will not need as much of the pipe cut out to fit it in. If you use PVC, or ABS, get a "street tee" so you only need a piece of pipe on the top end.
Some places don't want pvc stuck in the middle of a CI stack. But, if it really is self-supporting, there should be no excessive pressure on it.
Molo
Cold New York
Would this be a no-hub street tee? Also by "street tee" do you mean the "leg" of the tee can have a piece of PVC pipe slide right over it?
Also, what is the problem in using a "Y"?
Thanks again
Tom Sawyer
Maine
Where is he going to find a street T? I'd bet that of the 6 plumbing supply houses near me, none of them carries a street T in any size. Charlotte and Mueller both say they make them though.
The pvc fitting will have hubs on both ends...the street T will only have them on one end. It might make getting the whole assembly just the right length when cutting out a section easier. If you go with a CI hubless fitting, neither end will have a hub. Getting the section of pipe just right - nice square cuts with the proper gap to slide in the fitting will be tougher.
Molo
Cold New York
There is a challenge to using the no-hub couplings that are available at the supply house. They have a "stop" half-way through the fitting (the rubber forms the stop). This "stop" will prevent the coupling from being slid up (or down) the pipe so that the new piece can be placed into the cut out area. In other words, I need a repair no-hub coupling. Are these made, or is there another way?
Thanks again!
MACPLUMB
HOUSTON, TEXAS
You take the rubber coupling and roll it back over itself then you
only need a extra 1/4" or so to slide your tee/wye into place roll rubber back down and slide
your metal band into place, ! be sure to tighten the nuts equally
