Condensation lines
Discussion in 'HVAC Heating & Cooling' started by sneezye, Dec 21, 2009.
  1. sneezye
    sneezye New Member
    Dec 2, 2009
    Barista!
    Tulsa, OK
    Would it be abnormal for an HVAC unit to have two condensation lines? I have two 3/4" pvc lines (one from each side of the unit) running down from my attic to the crawlspace under the house.
  2. jadnashua
    From what I hear, this is not abnormal...one is for the primary drip pan, the second is the emergency or secondary pan. If you ever walk by, you'd normally only see water coming from one. If you see it from the other, you have a problem, and it is time to fix it before you have a flood, ruining your ceilings and maybe walls and floor as well.
  4. sneezye
    sneezye New Member
    Dec 2, 2009
    Barista!
    Tulsa, OK
    and the next question...
    IF that were the case, could they be combined into 1 pipe?
    I am moving the pipes and would prefer to wye them together to avoid having 4 pipes running through my closet (the other two being the WH T&P and overflow). Not that 3 is that much better...
  5. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    No, you cannot connect them to one pipe.
    If you want to get rid of the secondary you should have a float switch installed (if possible with your existing arrangement) which would turn the unit off at a predetermined level in the pan.
  6. jadnashua
    The whole idea of a secondary line is it is an entirely separate path, so if one has problems, the other can take up the slack.
  7. sneezye
    sneezye New Member
    Dec 2, 2009
    Barista!
    Tulsa, OK
    Alright. I will leave it as it is. It's better to find things correct than to find things... well, messed up. Thanks, guys.
Similar Threads: Condensation lines
HVAC Heating & Cooling Condensation line issue Aug 15, 2013
HVAC Heating & Cooling cause of condensation in ceiling? Jul 15, 2013
HVAC Heating & Cooling LOUD DRIPPING - A/C condensation drain behind the wall Jun 28, 2013
HVAC Heating & Cooling excessive condensation cause? Aug 28, 2012
HVAC Heating & Cooling Condensation from the stack Dec 11, 2011
