concrete patch around basement toilet
Discussion in 'Toilet Forum discussions' started by taxman, Jan 24, 2005.
  1. taxman
    taxman New Member
    Jan 10, 2005
    I wanted a toilet put in my basement. I just had a plumber come out to my house and cut the basement floor and install the pipes. They patched up the floor with new concrete mix. But when I look down through some small holes on the outer rim of the flange, I can see that the concrete was not filled in all around the "neck" pipe that the flange is connected to. If you think of the flange as a clock, then there is concrete filled in from about the 8:00 position to about the 4:00 position. But from 4:00 to 8:00 positions, there is a void area where I can see the white pipe neck down below the surface. Why wouldn't they fill in this area with concrete, too, so that the entire neck is encased in concrete? Did they do it wrong?
  2. hj
    void
    No. In fact with "new" construction the void is around the entire pipe so the flange can be attached after the concrete is poured. If the flange ever fails you may be happy for that void and wish that it was all the way around the pipe.
Similar Threads: concrete patch
Toilet Forum discussions Oversize cast iron offset flange in a concrete floor. Sep 5, 2015
Toilet Forum discussions Concrete/Cement base for flange Aug 19, 2015
Toilet Forum discussions Toilet flange repair -Metal flange on concrete. Mar 21, 2015
Toilet Forum discussions Broken bolts in toilet flange in concrete slab Aug 18, 2014
Toilet Forum discussions cracked flange on concrete Jun 29, 2014
