Concrete Demoliton Advice
Xenomorph
I am trying to learn about doing concrete demolition the most efficient way, but am not having much luck finding reading material. I am interested in making small-medium sized holes, as well as occasionally making trenches. Should I go with a demoliton hammer? Or a full sized jackhammer? Or should I go with a demo/rotary hammer and a handheld concrete saw?
I am curious if some of the more powerful demo hammers like this one from Milwaukee ( http://www.milwaukeeconnect.com/web...product3_27_40027_-1_331654_281154_189337_362 ) can handle chiseling out a trench in pretty good time, or if you need to use a concrete wet/dry saw for something like that.
Thx.
Dunbar Plumbing
www.KoldBreeze.com
The quickest way to remove concrete would be to cut the concrete to be removed with a diamond blade concrete saw along with water running where you cut at all times; keeps the dust down and keeps the blade cool.
I've been using a 60lb electric jackhammer for years. Takes a little time but it eventually spider cracks the concrete.
Those 90lb air jack hammers you need to pull a compressor behind your vehicle are the way to really make mince meat of the job. They make a relatively lightweight air hammer that destroys concrete.
I speak mainly from past experiences, try not to do that type of work anymore.
Gary Swart
Yakima, WA
For breaking small areas of concrete and for drilling holes in concrete, I found a 3 function rotary hammer/drill to be very useful. You can buy one complete with some basic chisels and drill bits for about $100. These use SDS bits which are readily available. I got mine from Grizzly some time ago. You can use the attached address to get the the Grizzly site, then search the site for G9908.
http://www.grizzlyindustrial.com/
holes
It depends on the job's requirements. If you do not need a precise opening, then a few "whacks" with a 12# sledge will usually create a starter hole and then it is easy to enlarge it with the sledge or an electric hammer.
Toolaholic
General Contractor Carpenter
Marin Co. Ca.
I'm a gen. contr. with a lot of equept.
I have a 60 lb bosh. and 2, 47 lb makitas. 14 " gas concrete saw
for a slab cut out saw then jackhammer. If things get serious ,I have a 16,000 backhoe . I have the name toolaholic for good reason :D
