Hi. Tried to replace a compression fitting behind the toilet today. The sleeve puller is too big to work in such a tight spot. The valve is behind toilet with just a few inches between it and the back of the toilet. Is there a compact tool to get the nut and olive off, or maybe a right angle type tool? I don’t what to grind and cut off the nut as it’s too risky for me. I took the valve off but had to put it on again as I couldn’t get the nut and olive off. While off, I was able to tighten the packing nut which has helped reduce the leak. It’s 25 years old and could do with replacing I’m sure. Thanks all.
