Comfortnet Thermostats vs comparable thermostats with fan speed programming?
Discussion in 'HVAC Heating & Cooling' started by jfls49, Nov 20, 2012.
  1. jfls49
    jfls49 New Member
    Nov 9, 2012
    Prospect, PA
    I've just purchased a new Goodman heat pump and Air Handler. The air handler has a ECM fan motor and the brochure says the fan speed is variable. I'm guessing with the Comfortnet thermostat which costs about 379 dollars. It is a touchscreen etc..
    I am wondering if there is a plain non-touchscreen thermostat I could buy with same programming capabilities as the Comfortnet thermostats costing alot less than 379 bucks.
    Does anyone have any info to share?
    Appreciate the help.
  2. jadnashua
    I don't know how that one works, but on my variable speed air handler, there is no external control on the fan speed from the thermostat. There is an adjustment to specify the max CF/M for your system programmed into the air handler, but none in the thermostat which only has on and auto settings. On mine, the fan only runs at a very low setting in the on position unless heating or cooling is called for, then it adjusts based on the time the call is, ramping up to max if there's enough time, then back down to either off if in auto, or the lowest speed if in on.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    there is probably a honeywell which will do the job. ( The Goodman stat is quite likely made for them BY honeywell). Price will be about the same. When you get into the hi-seer/hi-featured world, just open up your wallet.
  5. jfls49
    jfls49 New Member
    Nov 9, 2012
    Prospect, PA
    More info to add
    Reading over the installation manual for the air handler, it says the Comfortnet allows the Heat Pump to tell the air handler fan motor how much CFM is needed, when im in the cooling and heating mode. The air handler regulates how much cfm is needed when in the constant fan and emergency heat pump modes. So basically I only have the Comfortnet feature in the air handler and not the heat pump unit. I am wondering will I be able to hook up the Comfortnet tstat and would it fault out without the heat pump comfortnet unit not capable. I guess I need to call Goodman tech people for specific answers.
    I'm even comtemplating getting a variable frequency drive and hooking it up myself to the ECM fan motor in the air handler. I just need to find a thermostat that will output 0-10vdc or 4-20mA signal to the drive to make it work. Maybe I can program one of those Arduino microcontrollers at Radio Shack to work.
Similar Threads: Comfortnet Thermostats
HVAC Heating & Cooling Per-room Line voltage mechanical thermostats - upgrade options? Nov 25, 2014
HVAC Heating & Cooling Comparing 3 Thermostats White-Rodgers, Lux and Jackson Jun 8, 2013
HVAC Heating & Cooling wirelessly communicating thermostats Apr 4, 2012
HVAC Heating & Cooling How Many Thermostats for 3 Attic Exhaust Fans? Sep 3, 2008
HVAC Heating & Cooling Do all thermostats switch reversing valve every at every start? Jul 21, 2008
