cold water surge in re-circ system
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Artcraft, Mar 31, 2010.
  1. Artcraft
    Artcraft New Member
    Feb 12, 2010
    California
    I replaced a re-circ line for a client, water heater and added uponors demand pump with motion sensors. While showering about five minuits into and at approx recurring intervals the water is not going cold but just going to lukewarm for about 5 seconds and then returning to normal temps. this happens in both showers in the house older non pressure balanced valves. I replaced the line with pex could have the velocity increased due to the smaller inside diameter of the pex and could this be effecting the older valves? Any other thoiughts
    thanks
  2. Jeff1
    Jeff1 New Member
    May 24, 2006
    So Cal
    What is the time interval on the motion sensors?
  4. Artcraft
    Artcraft New Member
    Feb 12, 2010
    California
    Once water reaches temp aquastat shuts pump off. does not allow motion to turn it back on untill after the water at the aquastat cools off. I replaced the pump once thinking the intragal check valve was bad, uponor was great to deal with but it did the same thing
    thanks
Similar Threads: cold water
Plumbing Forum, Professional & DIY Advice Broke my cold water stem for my shower. Options? Tuesday at 10:06 PM
Plumbing Forum, Professional & DIY Advice Moen shower head cold water only after shower remodel Jan 18, 2017
Plumbing Forum, Professional & DIY Advice Cold Water Line to Kitchen not Working Jan 9, 2017
Plumbing Forum, Professional & DIY Advice Cold water relief valve question Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Cold water supply line connected to cast iron main stack? Oct 27, 2016
