Code requirement for custom shower drain?
Discussion in 'Shower & Bathtub Forum & Blog' started by Stealthfox, Dec 11, 2007.
  1. Stealthfox
    Stealthfox New Member
    Dec 11, 2007
    Hello all, i'm a tile contractor looking at a custom walk in shower, the size of the shower pan is approx. 8.5 ft wide by 3.5 deep, with a showerhead on each side of the short walls
    local plumber tells me you need (2) 2" pvc drains for this setup, HOWEVER because this is a handicapped accessible shower the customer has already lowered the subfloor under the shower area so that the finished mortar bed height is equal to the rest of the floor.....no curb, and wheelchair rolls right in
    the lowered floor means some sistered joists, and this takes up the needed room for 2 drains.....sooo the plumber says we need (1) 3" drain instead
    1) is this correct, i live in the st. louis mo area if that makes any difference
    2) my real problem is that as the tile contractor i want to use a shower waterproofing system made by Schluter Systems called "KERDI" and they make their own drain to fit their waterproofing membrane, and it only comes in 1 size of course, the standard 2 inch....i don't know if there is a way to modify a standard 3" drain but maybe some of y'all might know about that??
  2. jadnashua
    Kerdi is good stuff, but like any typical shower drain, it is designed for 2". I'm not a pro, but I don't see any good reason why you'd need two drains with only two showerheads...people get buy with 4-5 or more with only one. I loaned my TDNA handbook to someone so I can't see if they require two because of the size of the room, not the quantity of the heads. Have you checked with the inspector? The plumber might be right on, or he could be blowing smoke.
    Schluter talked about maybe making a trench drain, which might work for you. You might want to ask (I don't remember it in the catalog, but sometimes they have some things that aren't), but absolutely no guarantees.
  4. jimbo
    jimbo Plumber
    This raises a very interesting question.... I believe the code for a 2" shower drain was written with the assumption that everyone had 1 showerhead! I can see that a "thinking" inspector might add up ALL the available heads in a shower and base a drain requirements on perceived maximum input?
  5. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    fight code with code. you are going to have to know more about code than the plumber is expecting you to know, to get him to back off.
    i think your plumber is thinking the floor surface area or the TWO showerheads now makes it bigger than ONE shower, so he concludes it needs a bigger drain.
    he is wrong.
    david
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Ask him to show you in his code book the requirement for the 3" drain.
    If he doesn't, go with the 2" drain and be done with it.
  7. Stealthfox
    Dec 11, 2007
    contacted the local county inspector and he said the plumber was "dead wrong"......nuff said
    1 drain, 2" pipe thats all ya need ....i'm relieved
  8. elvisclock
    elvisclock New Member
    Mar 22, 2005
    Are there going to be any body spays as well. He could also be recommending two drains since there is no curb the two heads could put out more flow than the one drain could keep up with.
Similar Threads: Code requirement
Shower & Bathtub Forum & Blog Installing code-compliant 2 handle shower faucet Jun 20, 2016
Shower & Bathtub Forum & Blog Code Question for faucet handles May 27, 2016
Shower & Bathtub Forum & Blog Antique "Standard" bathtub code? Mar 5, 2015
Shower & Bathtub Forum & Blog Drain height code for curbless showers Sep 22, 2013
Shower & Bathtub Forum & Blog S-trapped on plumbing code Mar 12, 2013
