Code question 277 and 24 volts same fixture.
Discussion in 'Electrical Forum discussion & Blog' started by Lionsfniniowa, Sep 27, 2012.
  1. Lionsfniniowa
    Lionsfniniowa New Member
    Sep 27, 2012
    Iowa
    Here is my case. I hired a contractor that wired 277 volt floesent fixtures. He added a 12 volt motion sensors on the circuit. Instead of placing the control box on a servicable wall he place them inside the first fixture under the canopy. Is this legal? I thought you could not mix wire voltages in the same box. As far as I know fixtures cant be used as a junction box? This is in a school in the State of Iowa.
  2. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    Can't say for sure from what you have described. You can use the fixture to junction wires that are associated with the light. As far as mixing voltages it depends on how the motion sensor is meant to be used.
    The person that can give you a complete answer is your electrical inspector.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    As long as the insulation of the low voltage is rated for line voltage then they can be in the same enclosure.
    What make you think that the sensor is at 24 volts?
  5. jimbo
    jimbo Plumber
    San Diego, CA
    I was kind of wondering about that....not so common.
Similar Threads: Code question
Electrical Forum discussion & Blog Bathroom remodel code question Jun 7, 2016
Electrical Forum discussion & Blog Electrical code questions. 2005 NEC Jun 15, 2015
Electrical Forum discussion & Blog Code Question: Safely Storing Future Use Wires Jul 31, 2012
Electrical Forum discussion & Blog Code question on multi-location dimmers ( lutron / maestro ) Dec 28, 2009
Electrical Forum discussion & Blog Misc Residentual Code Questions Jan 28, 2009
