Hi there, I'm doing a basement renovation and discovered I have two 3" floor drains. One is for the furnace and AC unit and it is beside them. The second was for the Laundry area, but the drain is in the middle of what I'm going to call the living room. I'm moving the laundry room beside the utility room, so I'm wondering if I still need the floor drain in the future living room. For the living room drain there are also 2 nearby black hoses going into the concrete. 1 black hose held the trap primer, the other one doesn't seem to be used. is it a breathing tube?
My main question is this, can I close off the drain in the floor with something like SureSeal since I don't have a trap primer there anymore. Or will that cause a problem after I cover it with vinyl plank flooring. Or should i cement it in?
