clogged toilet
Discussion in 'Toilet Forum discussions' started by lauriebee, Oct 5, 2009.
  1. lauriebee
    lauriebee New Member
    Oct 5, 2009
    maryland
    The toilet upstairs nearly overflows and then drains very slowly. The upstairs bowl, however, abruptly empties when I flush the toilet in the basement. What is wrong with the upstairs toilet?
  2. jadnashua
    Sounds to me like you have a partial clog in the line below the upstairs toilet. When you flush the downstairs toilet, it creates a suction that breaks the clog.
  4. Runs with bison
    Runs with bison Member
    Aug 23, 2009
    Midwest
    Yep. I had a toilet that was experiencing some line obstruction. The plunger and a short snake did nothing for it. I discovered I could sometimes use water flow in the tub to create a venturi effect and suck the toilet level down so that it would flush. I eventually had the line augured out along with the vent stack and other branches.
    When you are paying someone to do such a nasty job, get everything cleared and make sure to chase all the garbage out with a lot of water in all branches before you release them. Otherwise you can end up chasing a clog around from branch to branch. The plumbers were a bit skeptical but humored me when I systematically started flushing branches...until a line that was free flowing a few minutes before (they had witnessed it) revealed that it was now completely clogged. That was when the really nasty work began, but they got it all.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    You need a professional plumber that can do a complete job on your drains. Do not use chemical drain cleaners. Not only do they not work on clogs like you have, the will create a hazard for the plumber you will eventually have to call.
Similar Threads: clogged toilet
Toilet Forum discussions When toilet's clogged, flapper won't close Aug 9, 2016
Toilet Forum discussions Toilet clogged? Please help Jan 26, 2016
Toilet Forum discussions Toilet won't stay unclogged Sep 7, 2015
Toilet Forum discussions Clogged toilet, shower, sink combo May 6, 2015
Toilet Forum discussions New Drake Toilet Clogged Apr 15, 2014
