Clogged Sink? Just replace all the pipes!
Verdeboy
plumber1 said:
Can't you make an access door in the room behind the business end of the tub? You sure could have used one.
What P-1 means is that it's a lot easier to install this gasket from the outside of the tub. Usually there is a plumbing access panel, from which you can access the tub drain. If not, you'll have to scrunch up the gasket to get it through the overflow hole from the inside.
Cookie
Home
I did it from the front and it was fine. Not that hard. Thank you Verdeboy. I also bought some product at Pool City to clean the jets, and that worked fine, too.
