Clear Toilet Clog
Discussion in 'Drain Cleaning' started by kingtomato117, May 10, 2009.
  1. kingtomato117
    kingtomato117 New Member
    May 10, 2009
    My son stopped up the toilet it appears he used a bendy piece of a window shade the thing you twist to open it to light in. Well a piece broke off in there he said and now it is draining slowly. We're afraid to use it for now so toilet paper and anything else doesnt get caught on it. Is there a tool a homeuser can buy or would we need to contact someone?
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Buy one of those cheap closet augers from the big box store. Make sure you do not damage the bowl/porcelain.
  4. kingtomato117
    May 10, 2009
    Thanks for the reply. Will that allow me to grab it and pull it up on this side? I dont really want it to get stuck in a pipe or anything. I dont know if it would, since I don't know anything about plumbing lol. But Ill look in to one of those. Thanks again.
    EDIT: I actually read about it and I see why that may work. Ill let yall know. Thanks
  5. plumbingskool
    plumbingskool Retired Tradesman
    Feb 25, 2008
    Not Sure ;-)
    Ya, That will work for sure, :)
  6. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I've never seen anybody have much luck with a cheap closet auger.
    I use a 3' general auger with a drop head.
  7. hj
    What you need is a small mirror, and a flashlight to see where it is jammed. Once you do that, you can probable either pull it out, or use a bent coat hanger to dislodge it so it can fall back into the toilet so you can throw it away. I used my Ridgid Mini See-Snake to locate a customer's hair pick stuck in the toilet and then used it to guide me as I used a piece of wire to grab it. Like a surgeon doing a stent while watching the monitor.
  8. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    A PHD in toiletology¿ :rolleyes:
  9. kingtomato117
    May 10, 2009
    Well I bought an auger from Wal-Mart and it seems to have cleared the paper that was already stuck on it. I wasnt able to actually pull it back up on this side. Im going to try again here in a minute. Im a computer guy so I have a small pen-size webcam Im thinking of dropping that son of a gun in there.
    EDIT: Just tried and I got it with the auger this time. Thanks
Similar Threads: Clear Toilet
Drain Cleaning How should I clear condensate drain? Mar 16, 2014
Drain Cleaning Need Help Identifying How To Clear A Section Of 4" Sewer Line In My Basement Sep 29, 2012
Drain Cleaning Clearing blocked condensate drain pipe for AC unit Aug 13, 2012
Drain Cleaning PVC storm drain line has serious roots -- clear it? or start digging? Nov 9, 2011
Drain Cleaning Vent cleaning/system clearing Mar 30, 2011
