"Clean" Romex installs...
Discussion in 'Electrical Forum discussion & Blog' started by cacher_chick, Dec 30, 2009.
  1. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Maybe a silly question, but for the sake of good practice and appearance, when running wire is there a preference when it comes to pulling 2-3 cables through a single hole in a stud or joint OR drilling a separate evenly spaced hole for each cable? For clarification, I mean common residential receptacle and lighting circuits.
  2. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I run up to 3 cables thru a hole (#12 or #14)
    Less holes in joist etc the better
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Typically, up to four NM cables in a hole will NOT cause or bring up any issues.
    2x4's I usually drill 7/8" holes dead center. Bigger framing gets 1" or 1-1/8" holes.
  5. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    We always put multiple cables in a single hole. As many as will comfortably fit.
  6. codeone
    codeone Code Enforcement
    Sep 5, 2008
    Code Enforcement, Instructor
    North Carolina
    For 2008 NEC, Article 334.80 for Ampacity of NM cable states.
    Where more than two NM cables containing two or more current-carrying conductors installed, without maintaining spacing between the cables, through the same opening in wood framing that is to be fire- or draft- stopped using thermal insulation, caulk, or sealing foam, the allowable ampacity of each conductor shall be adjusted in accordance with Table 310.15(B)(2)(a) and the provisions of 310.15(A)(2) shall not apply.
    Where more than two NM cables containing two or more current-carrying conductorsare installed in contact with thermal insulation without spacingbetween cables, the allowable ampacity of each conductor shall be adjusted in accordance with Table 310.15(B)(2)(a).
    Table 310.15(B)(2)(a) Adjustment Factors for More Than
    Three Current-Carrying Conductors in a Raceway or Cable
    Number of ---------------- Percent of Values in Tables
    Current-Carrying ------------- 310.16 through 310.19
    Conductors ---------------- Adjusted for Ambient
    --------------------------- Temperature if Necessary
    _________________________________________________
    4 - 6 ______________________80
    7 - 9 ______________________70
    10 -20______________________50
    21 -30______________________45
    31 -40 _____________________40
    41 and above__________________35
    Being that you can use the 90 degree column for derating purpoes its not usually a problem with #14,#12,and #10 conductors untill you pass 9 current carrying conductors.
    That would make 4 cables = to 8 current carrying conductors since the exception doesnt apply.
    or you could have one of the cables be a three wire then 4 would equal 9 current carrying conductors and would be ok.
    Sorry havent figured out how to get the Tables to look right.
  7. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Just a quick note.
    Don't for get that the neutral of a MWBC (multi-wire branch circuit) does not count towards derating, so for home runs or branch circuit wires you can even have four 3-wire cables. In fact, only two of the conductors in a 3-way switching setup will ever carry current so IMO they apply as well, although it is not written that way.
  8. codeone
    Sep 5, 2008
    North Carolina
    Thanks for pointing that out Speedy Petey.
    Mel
Similar Threads: Clean Romex
Electrical Forum discussion & Blog Backside of finished wall in basement romex? Jan 25, 2017
Electrical Forum discussion & Blog Romex to THHN conversion in house junction box Oct 2, 2016
Electrical Forum discussion & Blog Replacing Romex with MC flex cable - boxes and connections Feb 14, 2015
Electrical Forum discussion & Blog Two 12-4 Romex cables through the same floor joist holes Jul 5, 2014
Electrical Forum discussion & Blog Can I use 1950 junction box with ROMEX® ? Jun 14, 2014
