Clack valve - Refill port plug leaks
electrotuko
Austin, TX
Clack WS1EE used on a iron removal filter/tank, Backwash only valve.
After a month after an installation it started leaking from a Refill Port Plug.
The water drips (1 drop/hour) from the locking clip holes.
I removed the plug, visually inspected, all looks good, O-ring looks good, clean.
Lubricated with silicon, re-seated. Still drips.
Removed plug again, removed O-ring, wrapped few turns of Teflon tape on the plugs neck, to make O-ring sitting higher, making more tight contact O-ring – Valve body.
Still the same.
What can be a root cause?
electrotuko
Austin, TX
Posting image of the leak place.
electrotuko
Austin, TX
When Clack is in a service-"home" mode there is a full water pressure under that refill cup.
Not sure if this is normal. I have inspected a spacer stack assembly, it all looks good.
Replaced refill port plug with new and new O-ring (no teflon), same issue.
One thing I noticed that, since it is a backwash only filter configuration, there is no Regenerant piston installed.
ditttohead
Water systems designer, R&D
Ontario California
That portion will be pressurized, it should not leak. If you replaced the cap and o-ring and the problem persists, then you have a flaw in the valve body.
