city supply line into hydronic system
Discussion in 'Boiler Forum' started by rrekih, Dec 19, 2009.
  1. rrekih
    rrekih New Member
    Oct 4, 2009
    Canada
    When after filling the hydronic heating system do you need to have the city supply turned on into the system?
    Does the system use water and need refilling?
    If you have a leak wouldn't it be better to let the system run down and shut down the system?
  2. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Yes you need to always have pressure in the system (12-17# cold). You need to install a boiler feed to maintain a constant pressure.
    You don't want to let the water pressure drop to 0 because you're always going to have SOME evaporation in the system.
  4. msgale
    msgale Member
    Sep 28, 2006
    there a 2 schools of thought on this:
    if you automatically refill your system, the homeowner may have a leak and it could remain undetected, with replacement water( with its own oxygen supply,which is bad) taking care of keeping sysyem filled.
    if no auto refill,then a leak means your system pressure drops, and eventually the homeowner is aware there is a defect
  5. msgale
    msgale Member
    Sep 28, 2006
    normally a normal system loses a tiny amount of water, which you refill maybe once a month or so. if there is a leak, i think you are better off knowing about it.
    otherwise a hidden leak could go on forever, with automatic refill ,and rot your joists etc,
  6. Doherty Plumbing
    Jun 22, 2009
    Penticton, BC
    You could argue it either way really. But you were worried about it I'd suggest the person install an automatic fluid feeder.
Similar Threads: city supply
Boiler Forum Insulating PEX supply and return in CH system Dec 25, 2016
Boiler Forum water supply valve for gas boiler not fully closing Oct 12, 2016
Boiler Forum Is it efficient to have combi boiler supplying hot water only during warmer months? Apr 10, 2016
Boiler Forum Supply and return sizing Sep 12, 2015
Boiler Forum How can i tell supply from return? Jun 6, 2013
