Chrome Drain Pipe to Cast Iron
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by raybigto, Mar 12, 2007.
  1. raybigto
    raybigto New Member
    Feb 15, 2007
    In redoing our bathroom, I found a chrome 1.5" pipe connected to cast iron. Is there a fitting out there to connect the chrome to pvc? Or is it best for me to remove the chrome piece? The chrome pipe was previously hack sawed and has some wrench marks and slight indentations... Originally, it was plummer puttied all over and leaked. Anybody seen this before? Thanks a million.
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Do your self a favor and cut out the whole T and hub below it and replace it with a PVC T, pipe and use banded couplings to connect it to the existing pipe. Get as close to the floor while leaving enough pipe to do the job and then a little more incase you make a mistake. I would also replace as much of the vent pipe as you can also. Be carefull when you cut the pipe it may need to be supported, looks like 2". You could also install a C/O maybe in the room behind the sink if it's not going to be finished.
    You will be way ahead of the game if you do.
  4. TedL
    TedL New Member
    Sep 17, 2006
    NY Capital District
    Cass's solution is optimum, but if you're not up to cutting cast iron, you can clean out the fitting that the chrome goes into, get a Fernco donut to put in the fitting and come out with 1.5 PVC and solvent weld an adapter that will accept the tubular brass or plastic trap.
  5. coz
    coz New Member
    Feb 27, 2007
    MA
    Cass is right on the money... cut the whole thing out and replace with plastic.It will make things easier in the long run.
  6. raybigto
    raybigto New Member
    Feb 15, 2007
      File size:
      92.6 KB
      947
  7. raybigto
    raybigto New Member
    Feb 15, 2007
    "t"
    for those following, I've decided to remove the T and replace with ABS and connect to the Vent above and Cast Iron below. Then attach a marvel fitting... Thanks all for your help.. I probably wouldn't have had the guts to do this without your input.
    p.s. the 1.5" chrome is indeed soldered with lead.
  8. Cass
    Cass Plumber
    Nov 12, 2005
    In my NSHO I think your making a big mistake by not cutting the cast at circle #2 and replacing it all. It is so easy now and would take hardly any time to do. Even if it took you a whole day, which it shouldn't, it would be well worth the time and few $$$ spent.
Similar Threads: Chrome Drain
Plumbing Forum, Professional & DIY Advice Help with 1 1/4 chromed lav sink/vanity drain set up May 18, 2014
Plumbing Forum, Professional & DIY Advice Chrome Drain Offset Oct 2, 2008
Plumbing Forum, Professional & DIY Advice Stainless S,or Chrome for Basket Strainer/drain for Kitchen ?Too many scratches Jun 14, 2008
Plumbing Forum, Professional & DIY Advice removing chrome drain pipes Mar 21, 2005
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
