changing house supply connection
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jasontf, Jun 2, 2011.
  1. jasontf
    jasontf New Member
    Jun 2, 2011
    Texas
    I need to change my main house shutoff from a gate valve to a ball valve. I have 3/4" soft copper coming in and 1" galvanized pipe inside. What is the best way to make this connection?
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    can you send a picture not enough info.
  4. jasontf
    jasontf New Member
    Jun 2, 2011
    Texas
    I can't get a picture now. It's an old house. I have 3/4" soft copper to a compression fitting, then a threaded gate valve (1"), then a galvanized union (1"), then a short galvanized nipple (1"), and a galvanized tee to go into the house (1") and into a hose bib(1/2").
  5. hj
    The obvious answer would be to use a 1" ball valve and spend a couple of hours to adjust the galvanized piping as necessary, possibly making multiple trips to the Ace Hardware store, to make it fit. Or call a plumber who can do the whole thing in a matter of a half hour or so.
Similar Threads: changing house
Plumbing Forum, Professional & DIY Advice Changing direction of new PVC pipe while replacing slab on grade in new house Nov 13, 2012
Plumbing Forum, Professional & DIY Advice Changing water pressure on house pressure regulator. Apr 30, 2010
Plumbing Forum, Professional & DIY Advice Changing main shutoff Oct 17, 2016
Plumbing Forum, Professional & DIY Advice Garage washing machine : changing from 1" drain to 2" drain pipe May 28, 2016
Plumbing Forum, Professional & DIY Advice Need advise on changing main Sewer Trap. Sep 2, 2015
