Centaur Carbon Filter ?'s
Discussion in 'Water Softener Forum, Questions and Answers' started by jfr121, Dec 7, 2012.
  1. statin
    statin New Member
    Oct 22, 2008
    Wisconsin
    Hello, I am curious how this project turned out. I actually am planning a similar project and surprised to find someone doing the same. If by any chance if the OP could either PM or post his results. Thanks, John
  2. statin
    statin New Member
    Oct 22, 2008
    Wisconsin
    I am in the planning stages for a similar install as the OP. Would using an old water heater for retention tank be ok? If not what kind of tank? Thanks, John
  3. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    I'm using a 120-gallon galvanized tank the original installer provided. I would prefer a Polyglas tank of the same size, similar to those at: http://www.cleanwaterstore.com/contact-tank.html, since the geometry of the bottom drain facilitates draining the gunk out -- the steel tanks usually have an inverted-dome bottom, with the drain about 10" up. The size of the tank is dependent on several things, reviewed here: www.nmrwa.org/resources/training/ChlorineContactTime.pdf. The design of the tank also affects the size -- if its internal design makes mixing more efficient, you can reduce the size of the tank. One such tank can be found at: http://www.apwinc.com/retention_tank.html. Acccording to the patent, in that tank "A series of baffles in the mixing chamber are arranged in sinusoidal or saw-tooth pairs that can be oppositely arranged, so that the mixer turns a drop of water into hundreds of micro-bubbles of rotating fluid, which allows the chemicals to exit the mixer and react with fluid in a storage tank as much five times faster than previously known." Presumably this would improve the "baffling efficiency" referred to in the PDF from near-zero in an ordinary tank to something greater, perhaps close to 100%. Your mileage may vary. I'm going to try one.
    Having seen the inside of "an old water heater" tank, I wouldn't use it for much of anything.
  4. jfr121
    jfr121 New Member
    Aug 10, 2010
    Chicago IL
    It has been a long time since I made this original post and wanted to let everyone here who helped me out how everything turned out. I ended up using a Stenner 3gpd peristaltic pump and pump module to inject the hydrogen peroxide instead of the Chemilizer pump. The reason for this decision was that there would be no need to dilute the h202 with distilled or RO water using the Stenner pump versus the Chemilizer. This made it much easier on my dad and his arthritic hands, no carrying many gallon jugs of water and having to mix it up with the peroxide helped tip the scale. The system has been working for 6 months now and the water is great! No more rusty sinks, toilets, or showers. And it tastes wonderful for the first time in a long, long time. I still want to try a Chemilizer pump and will do so on another house sometime in the near future. Will let you know how well that turns out. Thanks again for all of your help, it really came in handy getting this system designed and working well. John
Similar Threads: Centaur Carbon
Water Softener Forum, Questions and Answers Convert Fleck 7000 Centaur carbon system to add chlorination / bleach injection? Apr 20, 2014
Water Softener Forum, Questions and Answers Carbon backwash system with chlorine question Mar 19, 2017
Water Softener Forum, Questions and Answers Drain size for kdf and carbon back washing filters Feb 5, 2017
Water Softener Forum, Questions and Answers Combined carbon filtration + water softening system in 2 tanks versus 1 tank Jan 23, 2017
Water Softener Forum, Questions and Answers Source for activated carbon / charcoal? Oct 27, 2016
