Caulking the Tub Spout Question
Discussion in 'Shower & Bathtub Forum & Blog' started by BobF, Jan 27, 2007.
  1. BobF
    BobF New Member
    Jan 14, 2007
    Los Angeles, CA
    I have a question about caulking a bath spout.
    I traced the source of a behind the wall drip to the tub spout. When water is splashed against the spout small amouts of water will make it behind the tub wall.
    The caulking around the tub spout looks questionable so I plan on applying a fresh bead. But I noticed that there's a small opening on the bottom of the spout that appears to be for a set screw. Should I attempt to seal this hole?
    I have read some online accounts where the routine is to only caulk around the top and sides of the spouts.
    And would it be good idea to remove the spout to see if there's a gasket in place and to check its condition? And, if so, is it difficult to remove a spout? Does it thread on?
    Thanks for any help,
    Bob
  2. jadnashua
    THere are two common ways for a spout to attach - press on compression fitting, and screw on. WHen there is a set screw, it is almost always a push-on, compression spout. Usually, loosening the set screw will allow you to get it off. Sometimes, there are directional teeth that help hold it in place and O-rings. These can be damaged when removing the thing. And, if the set screw was tightened too much, it might have dimpled the pipe and that can make sealing toughter when removing it unless setting it in the same place.
  4. BobF
    BobF New Member
    Jan 14, 2007
    Los Angeles, CA
    Jim,
    Thank you for the helpful information.
    In taking a close look at the spout I noticed that there was a small radial crack or possibly a cut outside of the caulk location. It looks to be a fallout of the spout installation when we had out house repiped a few years ago.
    I strongly suspect that this is where the water was leas through the fiberglass tub wall. I just caulked that area and recaulked around the perimeter of the spout, excluding the very bottom.
    I'll check it tomorrow and see if that took care of the problem.
    For now, I'll leave the spout in place.
    Thanks again,
    Bob
  5. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Take the spout off and caulk the hole where the nipple comes through the wall, put the spout back on then caulk the spout for cosmetic reasons.
Similar Threads: Caulking Spout
Shower & Bathtub Forum & Blog Caulking New Tub Valve and Spout Nov 18, 2005
Shower & Bathtub Forum & Blog Shower door rail has openings INSIDE the shower? Ruining caulking. Feb 20, 2016
Shower & Bathtub Forum & Blog Caulking around trim sleeve? Feb 13, 2016
Shower & Bathtub Forum & Blog Help, shower leaking around tile and caulking gap Dec 26, 2015
Shower & Bathtub Forum & Blog Is caulking necessary? Jun 16, 2013
