Cast iron waste pipe
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cz639, Sep 10, 2004.
  1. cz639
    cz639 New Member
    Sep 10, 2004
    My insurance company advised me to change this over to a plastic pipe. I'm really clueless with plumbing. But where exactly is this waste pipe located. Is it located underneath my basement floor or is it somewhere visible in the basement?
  2. jmariechambers
    jmariechambers New Member
    Sep 4, 2004
    More information needed
    You have certainly come to the right place to have your questions answered, however be ready there will be many more questions. For now I only have three:
    • Did the insurance company say why to change it?
    • Is the huse one, two or three stories
    • How old is the house?
  4. cz639
    cz639 New Member
    Sep 10, 2004
    The insurance broker said that over time it may rust and cause a leak and that you won't know that there's a leak until you actually see water leaking. I was told that the cast iron pipe contains sewage which would flood my basement and could cause further problems such as the formation of mold. I was told to change the cast iron pipe to plastic PVC to prevent this from happening because if it didn't I would not be covered by the insurance company.
    The house is one and a half stories tall.
    The house was built sometime between 1945 and the early 1950s.
  5. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    Need More Info
    Have the insurance company put in writing specifically what they want you to do and why.
    At that point, if it's justified you can bid the work out to local licensed plumbers.
  6. jmariechambers
    Sep 4, 2004
    It will be a lot
    First of all let me tell you that to replace what you are talking about will be expensive. Someone else on the bard will be able to give a better cost, but it will involve cutting into walls. A better idea is shop around for a different insurance company that will insure the house. I found it odd that they would only insure you if this was taken care of. Also, check with your neighbors, they should have similar DWV systems, and they may be able to suggest a carrier. I hope this helps.
  7. jadnashua
    Today, cast iron is considered a premium product - people pay extra for it. The main reason for this is that it is much quieter - you are less likely to hear the water running down the wall from the toilet, tub, or shower since the cast iron muffles it better than pvc. Depending on your local conditions, it can deteriorate, but usually lasts a very long time. PVC goes in quicker and isn't as likely to clog (not that a properly installed cast iron system clogs), mostly because the insides are smoother. If it is sloped properly, that doesn't happen much - the insides get a coating on it like a well-used frying pan. If stuff sits in it, it can be a problem, especially if your water is acidic (usually not a problem with public water supplies).
  8. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Criticism unfounded
    I suspect your insurance agent is projecting an uninformed personal view. We do have to replace some cast iron pipes but not normally like we do galvanized water pipe. I also suspect the statement that the insurance company will not cover cast iron pipes. Insurance Policies are not secrets. Go to the company web site and look at a sample policy is see if there is an exclusion for cast iron. And get a bid from another company.
Similar Threads: Cast iron
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Monday at 9:49 AM
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Monday at 2:24 AM
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Donut Sizing For Cast Iron Pipe Dec 23, 2016
