Cast Iron pipe - Lead removal and resealing
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by tnr122, Feb 28, 2010.
  1. tnr122
    tnr122 New Member
    Feb 28, 2010
    Moorhead, MN
    Hello,
    I had my floor cut open to add things in my utility room. The cast iron pipe was not buried very deep and by DUMB LUCK the cutters partially severed the pipe between a transition from 1 1/2" to 3". I am excited that I have 3" but have only 3/8" of the 3" pipe sticking out of the hub. My intention was to use a Fernco no-hub to connect to PVC but want to remove the stub piece and replace it with a few more inches instead of the 3/8". How do you recommend replacing the lead in a horizontal hub?
    Thanks
  2. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    take a torch to the lead and melt it till it all runs out. then dig out the oakum and remove the piece in the hub and install a new longer piece. They make rubber seals to use instead of the lead. not sure on your local codes on if they are ok or not.
  4. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    I'd drill a bunch of holes in the lead then pry out what remains.
Similar Threads: Cast Iron
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Cast iron sewer problems. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cast iron riser to toilet flange Feb 5, 2017
Plumbing Forum, Professional & DIY Advice 1950s cast iron sewer line clogged Jan 28, 2017
