Cap Plate Question
Discussion in 'Remodel Forum & Blog' started by idoc4u, Dec 14, 2009.
  1. idoc4u
    idoc4u New Member
    Sep 1, 2009
    Indiana
    From the image you can see that some of my duct work runs parallel to my joists. I would like to run an untreated 2 x 4 cap plate for a wall perpendicular to the joists and under the duct work. I would attach the studs to the cap plate that would be nailed into the joists.
    My question; is there any problem with nailing a cap plate into the joists directly under the duct? I will obviously be driving nails into the joist through the sheet metal and the 2 x 4 cap plate will be making contact with the duct, but the nails will be into the joist and not just sticking into the duct.
    Thanks for opinions.
  2. Ian Gills
    Jul 24, 2007
    USA
    I would screw it and not nail it and even then you might still get some problems with noise.
    And I would avoid going through the metal. You can get through the wood there.
    As the ducts heat up and cool down with your heating system they can sometimes make annoying sounds (especially at night) as they expand and contract around things they touch.
    Screws can sometimes help.
  4. idoc4u
    idoc4u New Member
    Sep 1, 2009
    Indiana
    Ian
    Thanks for the reply, Ian.
    In the case of the wall I intend to build, the top plate will actually end at the joist in the middle of the duct that you see.
    Therefore, the plate will run across the bottom of the duct as your looking at it in the photo from left to right and end at the middle joist where the duct is nailed in the middle.
    Screwing it in is a great idea, I just wasn't sure if I could run the plate across the bottom without creating too many creaks in the night.
    Thanks again.
  5. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    You could always use a piece of sill sealer in between the duct and the top plate. It would uncouple the two. Then screw it in place. Screws are easier overhead anyway.
  6. hj
    duct
    That is a return duct and there will be NO noise from it. Neither is there any problem with crossing under it or nailing through the metal "flanges'. In other words ignore it, forget it is there, and just do what you originally intended to.
  7. idoc4u
    idoc4u New Member
    Sep 1, 2009
    Indiana
    Thank you
    Thanks for your input, guys!
Similar Threads: Plate Question
Remodel Forum & Blog Plate? For canopy covering/porch Mar 22, 2017
Remodel Forum & Blog "Fill" or just seal foundation/sill plate gap? Aug 20, 2015
Remodel Forum & Blog Mass 8th Edition Base Code & Sole Plate Jun 17, 2014
Remodel Forum & Blog Methods for sealing sill plate to foundation? May 18, 2013
Remodel Forum & Blog XPS basement insulation and foundation sill plate Jul 30, 2012
