Can't remove trim from Kohler shower faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by altonloe, Dec 22, 2008.
  1. altonloe
    altonloe Engineer
    Dec 22, 2008
    engineer
    Seattle, WA
    I need to get the trim off my shower faucet. I called Kohler, and they say to twist the white part counter clockwise. I tried that and it won't budge. The brushed metal trim is firmly attached to the valve. I tried prying it off the wall, but it was obvious that it would not come off.
    The trim is Kohler part number T12014-4 BN.
    Thanks in advance for your help.
    Alton
  2. jimbo
    jimbo Plumber
    San Diego, CA
  4. altonloe
    altonloe Engineer
    Dec 22, 2008
    engineer
    Seattle, WA
    Yes, I did take the cap off, take out the screw, and remove the handle.
    What I can't figure out is how to remove the round white plate that is covering up all of the screws holding the cartridge in place.
    The manual says to turn it counterclockwise, but I can't get it to budge. That's my problem.
  5. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Spray some vinegar in there, let it soak for tweny minutes and then see if it doesn't budge.
  6. Thatsthedude
    Thatsthedude New Member
    Feb 12, 2013
    California,
    When you spin the trim in the middle there is a circular piece with two grooves. The circular piece is the one you turn counterclockwise to remove the trim.
  7. RichTech
    RichTech New Member
    Jan 3, 2015
    I had the same trouble. To solve this I got a rubber band, and centered it with the round white plate. Then I pressed down on the rubber band with my fingers and twisted the white ring counter-clockwise about 30 degrees. The ring popped right off after that.
Similar Threads: Can't remove
Shower & Bathtub Forum & Blog What is this part and why can't I remove it? (Moen shower 1225) Mar 31, 2016
Shower & Bathtub Forum & Blog Can't Remove Shower Handle (Kallista) Oct 26, 2015
Shower & Bathtub Forum & Blog Grohe - Can't see how to remove handle Sep 2, 2013
Shower & Bathtub Forum & Blog Can't remove bathtub shoe gasket Nov 24, 2011
Shower & Bathtub Forum & Blog tub spout just spins - can't remove and leaks Jun 27, 2010
