Can You Identify this Faucet Brand? Price Pfister faucet with a "C" spout
cstephen44
Chicago, IL
I'd like to replace my shiny brass faucets with their dark brown plastic accents but I don't know the brand, which I'd like to know so I can keep the existing valve. This is the sink, I have a roman tub filler as well that is the same. The only writing I can find is on the end of the spout/aerator and is corroded. My best guess is : 2 GPM MAX AST 1.181.1
If you are familiar with this faucet and don't know the brand, can you possibly tell me how to get the handles off? The top plastic plate doesn't pop off, I can't find a screw anywhere (except one on the tub filler spout). The demo guys will be here any day. I'd like to remove them without resorting to means that could damage my tub!
Thank you
It is a Price Pfister faucet with a "C" spout and Euro Trim. The top caps unscrew, but you will probably need a pair of pliers to get them started. They have a rubber "washer" under them which makes them tight after a few years. The handles are interchangeable with new versions. The spout is NOT.
cstephen44
Chicago, IL
Thank You So I understand you to say that I can't just replace the spout myself (I'm talking about the tub filler, not the lavatory sinks) without any plumbing skills, but a professional could do it by replacing the valve... is that right? Can the valve be replaced in a deck mount tub by going through the top or does the deck have to be opened up?
Thanks again for your reply
The handles unscrew after removing the top piece (you might damage the finish getting the top brass piece unscrewed though if you weren't careful). To get to the filler spout, you'd have to unscrew it from underneath, so whatever was required to gain access is what it would take.
If you want to replace the lavatory spout, then you HAVE to replace the entire faucet. The Roman tub trim and spout IS replaceable, however, with the proper adapters. Buy the lavatory faucets you like and the Roman tub trim to match it, and then see if they know what you need to install it, (it involves a spout adapter and escutcheon holders). The ONLY thing you can do to the lavatory faucets without getting a new faucet would be to change the handles to comtemporary versions, but most will be lever handles so you will need a new stem for the cold water to reverse its rotation.
