Can I use dryer plug for my steam generator?
Discussion in 'Electrical Forum discussion & Blog' started by mtls, Oct 10, 2007.
  1. mtls
    mtls New Member
    Oct 10, 2007
    I bought a steam shower generator with electrical requirement of 120V, 30amp. It has 3 wirings labeled as L, N and Gnd. Can I use the dryer plug(14-30R) using a 14-30P plug? If yes how do I wire it? Is the receptacle 220V or 120V? Do I need a transformer?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    The 14-30R is a 3 pole 4 wire grounding receptacle, listed as 125/250 volts, 30 amps. It is intended for machines like dryers which have 120 volt components, like motors and controls, and 240 volt components, like the heating element. You would measure 120 volts to neutral from each of the hot plugs, and 240 volts across the 2 hot legs.
    I will will wait for bobnh to let us know if you can legally connect a machine like that steam generator to this receptacle, using only 3 of the 4 wires.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    No
  5. BrianJohn
    BrianJohn DIY Senior Member
    Jun 22, 2007
    VA
    I do not see where the OP mentioned if this is 3-wire or 4-wire. If it is 3-wire absolutely NOOOOOOO, (well he can reconfigur boths ends). If it is 4-wire it can be reconfigured for 120 VAC use, but I would not do it.
    But how do you plan to dry clothes?
  6. Cass
    Cass Plumber
    Nov 12, 2005
    The dryer is 240V and uses a 2 pole 30A breaker, the steam generator uses 120V and will use a single pole 30A breaker. This info is based on the info you provided.
    Based on the questions you asked, I suggest you call a licenced electrician to change this circuit over for you.
  7. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    I said in my initial reply: "Is it to code? I don't think so." I haven't been able to find a citation in the NEC. The applicability of the code usually ends at the receptacle, while utilization equipment is covered by UL.
    One issue would be how to terminate the unused conductor of the 3-wire + ground cord that probably comes from a dryer cord. That would not be a problem if a 2-wire + ground cord is properly attached to a 14-30P plug.
    The 2-pole breaker will trip if either pole exceeds the trip load so that aspect of it is safe.
  8. hj
    plug
    If you have to ask these questions you should not be doing it. Why do you wish to use the dryer cord? Is it because you want to use an existing dryer receptacle? If so, the safer method would be to replace the receptacle and wire it properly.
  9. jimbo
    jimbo Plumber
    San Diego, CA
    Thanks, bobnh. Your intial post fed in while I was typing my post. I had not seen your reply yet.
    For brian, the OP mentioned he was talking about NEMA type 14, which by definition is 3-pole, 4-wire, 125/250 grounding type. GOOD POINT about how will he now dry his clothes!!
  10. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    get a 220V one. They come in both voltages.
    Read the instructions. Call their customer support line.
    Then, with more reasonable questions, you can come to a group like this. Share what make, what web site, what you were told, what the instructions say, etc.
    Connecting a 110V device to a 220V circuit without the right plug and without any input from the manufacturer is dangerous/risky even when done by a highly experienced person on a temporary basis, like for a matter of seconds. You, on the other hand, ask dumb questions. You don't give any information. "Golly, I got this steam thing, and like ummm can I plug it in anywhere?"
    Describing how to jerryrig to this newly signed in member whose skill level is low, is not wise. There is so much about this question that is dumb. If the plug doesn't fit the socket, there are good reasons behind that!
    But, deleting the thread is also not good.
    I think it is also not good to answer with one-word answers. Doesn't turn people around.
    Newbies need interaction. They come wanting to discuss how to plug something in, but they really appreciate getting better answers, that give them some reasoning behind the apparent situation.
    So, instead of "answering the question", talk to low-skill newbies about their knowledge of risk.
    That is my take on what is appropriate. What Cass and HJ said fit the "requirements" good for a newbie. A bit of talk.
    David
  11. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I was always under the understanding that all these different receptacles were not made equal so that the proper mate to that recepticle would be the only one that would fit. Making both halves a matched pair. If you start making use of these receptacles as something they were not intended to be used for and someone comes along after the fact and plugs the intended appliance into your jerry rigged receptacle, bad things could happen. So my answer is also NO. And I'm not even an electrician.
    bob...
  12. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Is this steam generator an appliance? Yes
    Unless this steam generator is installed in a fashion that will allow for a quick removal, and this would be a violation of the plumbing code, then cord and plug would not be allowed unless the unit comes from the factory with a cord installed.
    The installation of cord and plug would be a violation of the NEC and to use one outside of the parameters of the listed use of the receptacle would also be a violation of 110.3(B).
    One of the biggest problems with a DIY web site is there are a lot of unqualified people giving less qualified people noncompliant advice.
    In short, the answer to the original question is NO!
  13. geniescience
    Nov 27, 2005
    ditto
    that was good. Good talk, real learning that I'll read a few times. The summary in that last line was clear too.
    david
  14. Bob NH
    Oct 20, 2005
    New Hampshire
    Maybe mtls got to read my reply before it was deleted.
  15. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    I think you're wrong on that detail, Mike. The steam generator at the Island house is on a cord, and plumbed in with compression unions. It's so that it can be dismounted and brought in every winter (it's an outdoor unit).
    I tried to attach the instructions for the unit, but the file's too big. You'll have to take my word for it that they specifically mention "if receptacle is desired, mount the box for the receptacle near the location of the Steam Generator".
    "SM-46 & SM-79" on this page:
    http://www.steamist.com/steambath-res-downloads.htm
    I agree with your overall point, though: the OP is messing with things they don't know enough about to do safely.
  16. arfeller
    arfeller Member
    Aug 25, 2007
    Port Angeles, WA
    Odd response for a DIY electrical forum... :confused:
  17. frenchie
    Dec 30, 2006
    Caretaker
    But we're not here to help people hurt themselves, either. Sometimes the question itself, belies such a lack of familiarity with the basic issues, that the best advice is "you shouldn't DIY that particular project".
    You have to know your limits.
    Example: I can spec out the beams for this renovation I'm planning, as far as the dead & live loads go. But as far as figuring out the shear loads, and designing the moment frame connections to handle it, I'm much better off just calling an engineer.
    The poster's asking about plugging a 110 appliance into a 220 receptacle... best answer is: "you shouldn't be messing with electricity". Anything else would be irresponsible on our part.
  18. geniescience
    Nov 27, 2005
    ditto
    ditto. Let's keep this as a reminder.
Similar Threads: dryer plug
Electrical Forum discussion & Blog NEED HELP!!! Having problems with dryer/amps to dryer I think.... Feb 12, 2016
Electrical Forum discussion & Blog Need branch ckt diagram for instllation of washer/dryer for permitting Dec 14, 2014
Electrical Forum discussion & Blog Dryer cord - 3-wire vs. 4-wire Nov 27, 2014
Electrical Forum discussion & Blog Dryer Static - modify dryer grounds....amicrazyorwhat? Nov 29, 2013
Electrical Forum discussion & Blog Old fuse box blowing large fuses but turn on dryer and power is back on? Dec 20, 2012
