I'm installing GoBoard for a shower which uses a liquid adhesive as the joint compound (instead of thinset and tape). However, for the drywall transition, the manufacturer recommends the cement board joint method- alkali resistant tape and thinset.
I'm going to be tiling over the drywall/GoBoard transition. Is there any reason I can't tape it and tile it in the same pass? Otherwise it just seems like a waste of time and money to do it on its own, let it dry, then tile.
In addition, the joint is going to be where a glass shower pane will be lined up and anchored. Any issue with this? Or should the joint and glass anchor points be offset?
