ajtisseve
Hi All,
Thank you for this great site! It has been a great help for the plumbing projects I have been doing around my house!
I'm currently remodeling my bathroom and the bath tub I would like to use has a center drain placement that is 1 inch further to the right than the current layout. The existing trap is set up exactly as the picture below.
Can I move this over? If so how? Do I simply loosen the middle joint with a wrench, re-position, then re-tighten?
I wanted to double check before I put a wrench on the joint in the middle and started applying a lot of pressure.
