can hear water running when neighbors water lawn
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by brendis, Jul 28, 2005.
  1. brendis
    brendis New Member
    Jul 28, 2005
    can hear running water when neighbors hose down lawn
    Hi,
    There is this weird thing that has been going on lately. When my neighbors water their lawn (hose), it sounds like someone has water running in our house.
    This happens even when no one in our house is using ANY water. Actually there has been two times when I come home from work to see their hose on and to hear that sound from our pipes in the wall.
    These homes are about 30 years old and are on separate lots (6000 sq ft each). The houses are not close to each other but the water meters are right next to each other near the curb on the neighbor's side. What could this be??
    We also have something like water hammer in one bath. Sometimes the banging goes on in the middle of the night when no one in the house is using any water.
    Thanks if you can help.
  2. Mad Plumber
    Mad Plumber Mad Skills
    Aug 13, 2005
    Plumming
    If you both have metal lines, then maybe that is makin the noise go bwteen the houses.
    It could be their faucet has noise in it.
    In the clunk in the meddle of the night, mybe its the ice machain in thar fillin up. Or it coud be the tartlet filinn. Check the flapper on thet one. and maybe e'ts it.
    If its the ice filler, then get a hammer device and that will stop it.
  4. jadnashua
    When you hear this, go out and look at your water meter. Does the indicator show water usage?
Similar Threads: hear water
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Today at 6:13 AM
Plumbing Forum, Professional & DIY Advice Did you hear about the watertight sealed bottom toilet flange? Dec 31, 2015
Plumbing Forum, Professional & DIY Advice Hear water running at toilet with valve off May 18, 2011
Plumbing Forum, Professional & DIY Advice just moved in to 40 year old home, heard gushing water, main water line broken Jun 30, 2010
Plumbing Forum, Professional & DIY Advice loud "knock" heard and now water trickle Jul 13, 2009
