Burying a water line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dripdrip, Nov 8, 2013.
  1. dripdrip
    dripdrip New Member
    Nov 22, 2008
    NE
    Hi. I'm burying a water line between buildings. I'm hoping to use polyethylene, and was told to surround it with sand by a plumber. (Yes, I'm going below the frost line.)
    Can I sleeve it in schedule 40 PVC *instead* of using the sand?
    Thanks,
    DD
  2. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    Yep, we do it all the time using 4" sch 40 for the sleeve
  4. hj
    The one I did a couple of days ago was surrounded by "dirt".
  5. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Why would you avoid using sand around the pipe? You don't need to use a plumber to shovel sand. Any DIY'er can do it. You don't need a truckload of sand. You can pick up a few bags of sand at most any big box store.
  6. Caduceus
    Caduceus Master Plumber
    Oct 16, 2013
    Just a Plumber
    Pittsburgh, PA
    It's always advisable to 'snake' HDPE or PEX water services in the ditch, y'know kinda side to side like a snake (not snake like a sewer snake). This allows for expansion and contraction of the pipe. In my area we don't sleeve with pvc except for the last 10 feet or less before entering the home and any sleeving in the ditch is done with the next larger size of HDPE so that there is some giving when expansion/contraction occurs.
  7. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Another vote for sand.
  8. Caduceus
    Oct 16, 2013
    Just a Plumber
    Pittsburgh, PA
    Yeah, I left that out of my last post. I would just do sand, too. Best protective fill for plastic pipe. You could even run a locator (copper) wire in the ditch in case you need to find it in the future.
  9. dripdrip
    dripdrip New Member
    Nov 22, 2008
    NE
    Well it's about a 100 foot run, and the backhoe bucket is 16" wide. So roughly how much sand would I need? Does it just need a little all the way around the pipe?
  10. dj2
    Aug 13, 2013
    California
    Good thing that you asked!
    The pipe should have 2-3 in under it and 2-3 in around it. The rest can be dirt.
  11. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Don't go 16 inches wide, save sand.
    Using bag sand is a bit if a joke.
    Get a load delivered.
    Good Luck on your project.
  12. hj
    About 2 cubic yards or a bunch of bags, neither of which are "cheap".
  13. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Well... that was before I knew it was a 100 foot long trench a foot and a half wide. I don't know how deep the frostline is in NE, but I assumed a trencher cutting a 3 inch wide trench.
    That's not to say you cannot make a narrow trench in the bottom of that mammoth one. One has to wonder what the existing material is and just how hostile it might be to the pipe.
  14. hj
    I either use the "hostile" dirt, or let the customer furnish, and place, the sand, then backfill the trench.
Similar Threads: Burying water
Plumbing Forum, Professional & DIY Advice Reburying water line Jan 11, 2016
Plumbing Forum, Professional & DIY Advice Cappping & Burying Water Pipes in Basement Sep 10, 2013
Plumbing Forum, Professional & DIY Advice Burying propane tank Aug 8, 2016
Plumbing Forum, Professional & DIY Advice Burying Copper Pipe Mar 5, 2011
Plumbing Forum, Professional & DIY Advice Considerations for Burying Sump Pump PVC Drain Pipe Feb 10, 2010
