Bronze/brass vs. plastic shower drain
Discussion in 'Shower & Bathtub Forum & Blog' started by bmw3034, May 14, 2007.
  1. bmw3034
    bmw3034 New Member
    May 14, 2007
    What are the pros and cons of a plastic (ABS/PVC) drain versus bronze/brass? While both meet code, is there an longevity or durability factor in using brass/bronze? Which do most plumbers prefer?
  2. jadnashua
    The moving, visible parts, and those things that control it might better be brass - they'll hold a finish better that plastic. The actual drain line - plastic is probably okay. I did some remodeling at my mother's house over Christmas...the brass tub drain came apart in my hand, the pvc stuff was still good. The softer plastic is more liable to get the finish damaged because the plating is hard, and the plastic is much less so. The differences in thermal expansion means the bond won't be as reliable, either. My personal opinion.
  4. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    I prefer the brass drains for a few reasons:
    The plastic holding nuts can crack over time from being under the stress of being tight.
    Removal of that nut and reuse is impossible when they leak
    Brass however will not stay clean for long iin the conditions it is exposed to.
    An all glued PVC drain assembly is a nightmare to remove in close quarters; the brass holding nut can be removed along with the assembly, cleaned and reinstalled if the installer didn't properly bed the base of the unit.
    I get about 3 to 4 calls a year where the plastic nut broke and was leaking bad. Less than that I get a call rarely that a brass drain is leaking; most times the base is free floating allowing movement of the drain independent from the fixture.
Similar Threads: Bronze/brass plastic
Shower & Bathtub Forum & Blog Shower Pan: No concrete underneath plastic pan by orig bldr Nov 19, 2016
Shower & Bathtub Forum & Blog Bathtub install on basement slab - plastic below and on top of mortar? Jul 17, 2016
Shower & Bathtub Forum & Blog Plastic CPVC nipple? Oct 27, 2015
Shower & Bathtub Forum & Blog A WTF plastic fitting on old cast iron. Tub drain Jan 21, 2015
Shower & Bathtub Forum & Blog Delta R10000 installation...leave plastic screen in during soldering?? Aug 14, 2013
