Breaking out a 4-inch thick boiler in basement
Discussion in 'Remodel Forum & Blog' started by mugsymiller, Sep 1, 2008.
  1. mugsymiller
    mugsymiller New Member
    Sep 1, 2008
    Hi, I am pulling my hair right now. I have a 3-4 inch thick cast iron boiler taking up a lot of needed space in my basement area and I want it out!!! We have managed to get the sections broke apart , but the 4th section (about 20 inches in height)is so large that I know we will not be able to get it out of the doorway without breaking it. The sectioned parts are so heavy that I will have to have at least 3-4 big men to take it out. If anyone has any suggestions, besides a sledge, sawzall, (have tried these methods) please let me know. Every time we hit it, it slides closer and closer to my water heater and I am afraid it's going to get knocked off of the base and into it. It's quite the disaster and am desperately in need of help. Any suggestions please!
  2. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    How about hiring a guy with a torch to cut it?
    Tom
  4. hj
    boiler
    Do you have any idea how long it takes to cut, actually melt, cast iron with a torch? Something it wrong here. A 20" high boilet section should not be that big, and it is not solid metal so it should eventually break with a sledge hammer. Even, a 5' high by 4' wide end section would be heavy, but not impossible to move.
  5. Bill Arden
    Bill Arden Computer Programmer
    Sep 30, 2006
    computer programmer
    MN, USA
    I've always liked using a 4-1/2 inch angle grinder with those thin cutting disks.
    I've cut threw I beams and even 1 inch thick steel.
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Before doing that, have everyone involved take a very close look at your stairway. Four men at 150 lbs. each to carry a 300 lb. part would add up to nearly half a ton on two steps at about three feet apart, and a point load like that would quite possibly collapse my own basement stairs. A much better bet would be to cover the stairs with some long lumber so the heavy parts can be pulled up the stairs with a winch.
  7. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    do what HJ says to do....
    all you need to do is get a large sledje hammer
    and break it up into smaller pieces...
    It is cast iron so it
    should break up .if you smack it hard enough.
Similar Threads: Breaking 4-inch
Remodel Forum & Blog Slab floor breaking up around perimeter Oct 13, 2009
Remodel Forum & Blog Breaking concrete? May 3, 2009
Remodel Forum & Blog Another 4-Inch versus 8-Inch Sink Drill Question Jan 26, 2009
