Breaker keeps tripping
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by cjo, Nov 25, 2005.
  1. cjo
    cjo New Member
    Nov 24, 2005
    My 220V 20 amp breaker for my well pump will not reset after it trips. Any ideas? Thanks!
  2. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    You have a direct short somewhere in the wiring. Have an electrician or pump/well person check it out for you.
    Ron
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Did you turn it all the way off then back to the on position? This resets it. If you just turn toward on, it will not catch.
    bob...
  5. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    I had a customer last week with a bad breaker. We firgured this out becuase the thing wouldn't reset when the main breaker was off. Well, we talked on the phone, determined it could be a bad breaker, and i haven't heard back. I have talked the business since, but no mention of a pump problem. This is probably the exception to the rule.
  6. mrichi
    mrichi New Member
    Nov 26, 2005
    Easiest way to check the breaker is to remove the load wires,then try to reset. If it won't reset w/o the load wires attached, it's dead.
Similar Threads: Breaker keeps
Pumps and Tanks Well Forum & Blog. Water is life. pump keeps blowing circuit breaker Mar 6, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Circuit Breaker Question Feb 2, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pump breaker tripping Jan 16, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure dropping, breaker tripping Oct 28, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Cistern pump tripping breaker. Jul 1, 2016
