Bowl to floor, or tank to bowl
Discussion in 'Toilet Forum discussions' started by fishkiller, Mar 16, 2010.
  1. fishkiller
    fishkiller New Member
    Jan 11, 2008
    Should I set the bowl to the floor first, then attach the tank to the bowl or attach the tank first and then set the combined bowl/tank? I'm sure I'll have shimming to do. I plan on dry fitting the bowl alone so I can see where the shims are needed.
    Thanks,
    Jim
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I believe most pros assemble the tank to bowl outside and carry the whole thing to the installation site. As a DIYer, I find it easier to carry the individual pieces to the bathroom and set the bowl first then install the tank. I really think it's largely a matter of personal preferance. Dry fitting the bowl first to establish the need for shims is always the best plan.
  4. jadnashua
    Depends on how strong you are and whether you have room to lay down on the floor and still reach things to thread the bolts and tighten things down. I think if you can lift it, assembly it where you have room, then install. Don't carry it with the tank cover, as it might slip off and break plus it's unnecessary weight. I'd probably leave the seat off until done, too.
Similar Threads: Bowl floor
Toilet Forum discussions HELP: gerber 21-374 floor mount back outlet bowl waste outlet thickness Jan 29, 2013
Toilet Forum discussions Toto G Max - Leak between Bowl and Floor Mar 21, 2009
Toilet Forum discussions Help with leak between bottom of bowl and floor Aug 24, 2008
Toilet Forum discussions Is it correct 1.28 GPF is not determined by the toilet bowl but tank? Feb 14, 2017
Toilet Forum discussions Aquia wall-hung bowl, TOTO tank required? Feb 3, 2017
