Boiler expansion tank size
Discussion in 'Boiler Forum' started by technogirl74, Jan 19, 2012.
  1. technogirl74
    technogirl74 New Member
    Dec 7, 2010
    New York
    Husband and I are planning a new boiler install (seperate thread) but have a question regarding expansion tanks.
    right now on our boiler is what looks like a #30 extrol expansion tank. (Its leaking bad).
    We need to keep it going until our new boiler is installed.
    Does it have to be replaced with the same size or can we use a #15 extrol expansion tank. (Reason being that we can get one for free)
    Are they sized to the boiler?
    If the answer is no to using the smaller tank, at how many btus is the max for the smaller tank.
  2. jadnashua
    The size depends on the min/max temperature and the volume of water in the system and has nothing to do with the BTU rating. Heating x amount of water y degrees means it will expand z, and the z is what your expansion tank must allow. A bigger one won't hurt, but one too small will either wear out fast or allow the pressure to rise once it gets full.
    www.watts.com has a calculator on their site to determine the size you need (you could use the volume they come up with and then compare it to the size of other brands). You need to estimate how many gallons of water are in your whole heating system, though. If you take the length of the piping and radiators and add 2-10 gallons for the boiler, depending on the type, you should have a good WAG. the smaller one may be fine for your application, but you need to run the calcs first.
  4. technogirl74
    Dec 7, 2010
    New York
    Thank you.
Similar Threads: Boiler expansion
Boiler Forum Combi boilers.. Addional expansion tank? Aug 25, 2016
Boiler Forum Two expansion tanks in boiler system Oct 5, 2015
Boiler Forum diaphram expansion tank location on american standard ng boiler Jun 15, 2014
Boiler Forum Sizing a Boiler Expansion Tank Sep 23, 2013
Boiler Forum Boiler Expansion Tank Oct 12, 2012
