Blue water pipe?
Rayh78
Colonial Heights, Virginia
1950 built house.
At sometime sewer and water line replaced both in same trench.
Sewer is ABS.
Water line is some type of blue poloy pipe. Was is it?
A light color blue and not like the old blue/grey quest pipe.
Was connect with a barb fitting and hose clamp just like I have seen with the black poloy pipe used for main water lines.
Looks and feels like the black poloy pipe but a blue color.
thanks
boardable
San Jose, Ca
This is most likely PEX. Look it up. A very neat set up. I prefer copper but most likely the previous owner had a re pipe done in PEX for cost.
Rayh78
Pretty sure it is not Pex. I used a lot of that. And the blue is a lighter color from the blue pex I have seen.
All I know for sure is that it was installed before 1999.
Looks, cuts and feels just like the black poloy pipe I have used as water main lines to meter. Just never heard of it coming in a light blue color.
I just finished splicing into it as I needed to extend it under the house. Used the same barb union as the black well pipe.
Was galvinized from 3 ft out from foundation running thru crawl space to main shut off.
kookla50
Arizona
Could youplease look at my post from yesterday and tell me if this is the same pipe you were talking about. Blue outside black inside. Thanks
Craigpump
There are a few guys up here that use a light blue poly type pipe for the lines from the well to the house, it connects just like black poly with an insert fitting and double clamps. I think it is rated for 200 psi.
