Blocked Plumbing Vent
DaveC1
Oregon
Hi, I have a drain blockage in my kitchen I have not yet been able to clear. I went on the roof to try to snake down the vent. The vent seems to be blocked about 2 1/2 feet down. With a flash light I see no nests or debris.... It is as though it is intentionally blocked like it is an abandoned vent although it is in the right spot for the kitchen ( sorry for the confusion as we did major remodel 5 years ago which required adding vents).... Is there a reason the vent would be blocked and should I just break through it?
Look in the attic. You may find there is a bend that your snake is running up against.
WorthFlorida
Solutions
Orlando, Florida
Venting can have sharp 90 degree bends instead of long sweeps. Pour some water down the vent and it probably will drain.
