blanco kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gfe76, Jul 3, 2008.
  1. gfe76
    gfe76 New Member
    Dec 19, 2004
    Florida
    Blanco Harvest faucet, model 157-080-st with pull out spray.
    The body coming out of sink (where ceramic cartridge is located) is stiff to rotate. Can I take control lever off, unscrew large ring, lift body off and grease with plumber's grease? Is that how to get to o rings in body (not cartridge)? Sorry no pics.
    Second, the control handle has gotten a little stiff. How to grease it? Or is the cartridge going bad?
    thanks for thoughts.
  2. hj
    blanco
    That is the easy description of how to do it. In actuality, however, you normally cannot remove the "spout" unit without first removing the spout and hose. A tight cartridge almost always requires replacement.
  4. gfe76
    gfe76 New Member
    Dec 19, 2004
    Florida
    by "spout", you mean the faucet body coming up out of sink, right?
    To remove what I call the spout (the piece with hose that comes out of body where cartridge is located), do I have to turn off water under sink? I realize to replace the cartridge I must turn off water. How difficult to replace cartridge on these units? The cartridge is $55---why so much??? Any chance I could remove cartridge and grease it? It doesn't leak. Are these faucets that good????? I tried to call manuf but they are closed till 7/7.
    Thanks so much...
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The worst part of the job is finding the part and the parts breakdown to see how it comes apart. Foo-Foo always focuses on sales and not service!
    Because it's Blanco! If you wanted cheap you should have gotten Moen or, Delta!
    No they are not but, Blanco thinks they are!
  6. gfe76
    gfe76 New Member
    Dec 19, 2004
    Florida
    Thanks for the reply. I called Blanco and talked to a tech rep----who was quite helpful and is sending me a cartridge and "o" rings for free.
    I went online and found a schematic. I took it apart and used plumber's grease and things seem to work better----or it may just be psychological at this point. When the cartridge and o rings get here I may change them out.
    Everything else in house is delta, but wife had kitchen redone and fell in "love" with these two Blanco faucets in kitchen (one gets NO use!)
    Thanks again for everyone's help. this is a great site and I appreciate you taking time to respond.
Similar Threads: blanco kitchen
Plumbing Forum, Professional & DIY Advice Remove flow regulator on Blanco Meridian Dec 13, 2013
Plumbing Forum, Professional & DIY Advice Blanco faucet install Dec 13, 2012
Plumbing Forum, Professional & DIY Advice Danze vs Blanco Jul 18, 2007
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Recommended rough-in height for kitchen sink drain? Sunday at 11:21 AM
