Cleaning Black toilets
buffee
Missouri
Terrible, that I actually had to find a forum because this is driving me crazy! I have two black toilets(1200$) all of a sudden they have a white ring in them. I have tried everything to remove this ring. In the old days(white toilet) I'd fill the toilet with clorox for eight hours and that would be the end of those rings(of course white toilet/black rings...I have NEVER found one person who could tell me what I can safely clean black toilets with. If anyone can help, I'd so appreciate it. Thanks:confused:
Plumbs Away
Active Member
Tennessee
Muriatic acid. Buy it at any hardware store or home store. Make sure there is MUCH ventilation and don't get it on your skin or in your eyes. One good method for using it in the toilet is to pour about a half gallon through a funnel down the overflow tube of your toilet's flush valve. This will dissolve mineral deposits in the bowl rim channel and clear the water holes in the rim. Leave it to do its thing for a half hour or so, then brush the toilet bowl thoroughly above and below the water line. The end result will be improved flush performance and a sparkly black bowl!
JohnfrWhipple
BATHROOM DESIGN & BUILD
North Vancouver, BC
My buddy installed Black toilets in his old home years ago. They hated them. Just because they where so hard to clean. Like he ever did anyway. lol
Perhaps a sign like this outside the bathroom door might help in the future....
Koa
Honolulu, Hawaii
I have removed built up scale with razor blades. You might try a stainless single edge razor blade. I also use these blades I have for cleaning my windows since they will flex a bit on curved surfaces. Extreme sharp on both edges so need to be very careful.
Ettore Champion Scraper 5 in. Stainless Blades
Plumbs Away
Active Member
Tennessee
Yes, there are safer, less toxic, more environmentally friendly ways to do this. If you want to do it quickly and THOROUGHLY, use the muriatic acid. It's now available in a "green" formula with substantially less fumes.
FullySprinklered
Georgia
If I had a black toilet with a white ring, I'd just leave it there for a target. Last time I used a black one I thought I was going blind.
