1. Ed from chicago
    Ed from chicago Member
    Apr 25, 2005
    Chicago
    I know that black pipe is used for gas and hotwater applications, but why? Why can't galvanized steel be used? Thanks again for your expertise.
  2. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    Natural gas is reactive to the galvanized used in coating the pipe which therefore causing "flaking" inside the pipe. In my area you cannot use galvanized for this reason, even though the gas utility states that "their" gas doesn't do this. There are tons of gas lines and fittings that have galvanized mixed with black iron. Not too often have I heard of clogging directly to this stuation. Not a myth, just a code that covers the "what if".
  4. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    IRCC, Black Iron Pipe typically isn't used for potable-water applications. Gas, Oil, Air--yes. Galvanized typically is for water, and a poor choice at that.
    Jason
  5. Ed from chicago
    Apr 25, 2005
    Chicago
    So, galvanized pipe is used only for water service, because if used with gas, there is a chemical reaction of flaking, which causes clogs and reduced strength of pipe. Is this correct???
    Thanks Guys!
  6. PEW
    PEW DIY Senior Member
    It is my understanding, after talking to folks at PGW (Phila Gas Works), that the non use of galvanized pipe goes back to the early 20th centry and no longer applies to current gas. But, is still written into codes, which have never been updated.
    Paul
  7. Ed from chicago
    Apr 25, 2005
    Chicago
    Apparently in some cities and states black pipe does not need to be used for gas. I live in Chicago and black pipe is sold everywhere (city & suburbs) for the sole purpose of gas applications. This is confusing.
    Thnaks for all the input.
  8. jimbo
    jimbo Plumber
    Here any gas pipe exposed to the elements MUST be galvanized; not allowed underground, of course.
  9. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't know if natural gas causes a reaction with galvanized pipe or not, but traditionally black iron pipe is used for gas. Galvanized pipe is legal for water but is not a good choice at all. Generally copper is preferred for water although some new forms of pipe such as PEX is being used now. Black iron pipe is never used for water to the best of my knowledge.
  10. hj
    pipe
    These days black pipe is used for gas inside a building because it is cheaper. It has nothing to do with a reaction with the gas. Outdoors it has to be galvanized. Underground it is a black pipe with a coating, which is the poorest decision I have ever heard of, but then I am not one writing the code.
Similar Threads: Black Pipe
Plumbing Forum, Professional & DIY Advice Rate these NPT threads (black pipe) Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Waste arm removal from black cast iron vent pipe Dec 3, 2016
Plumbing Forum, Professional & DIY Advice Natural Gas Black Pipe Sizing question Dec 4, 2015
Plumbing Forum, Professional & DIY Advice Black pipe / gas piping installation - tightness vs direction Aug 29, 2015
Plumbing Forum, Professional & DIY Advice Natural Gas leak in black pipe in attic Oct 6, 2014
