Bi-yearly washer drain clogged - HELP !
Discussion in 'Drain Cleaning' started by Meekster, Apr 12, 2013.
  1. Meekster
    Meekster New Member
    Apr 12, 2013
    Tn
    Hey Ya'll,
    We have a washer drain that keeps clogging. It was a yearly thing to rent a Home Depot electric auger for $60 to remedy the problem. Tried chemicals but they worked so-so. We have all but stopped putting food in kitchen disposal. And No grease. Now it is clogging more than once a year and it is getting aggravating and costly. Not to mention cutting into my fishing time. I will post a picture of the set-up with hopes someone can give me some pointers. I can't figure out why and where it keeps clogging. Nothing but a minor muddy residue comes back on the auger cable. I tried running a hose down the roof pipe and sink with the clean out open and water doesn't come out. ??? That is what I call the "mystery area" between the sink and the problem washer pipe. I GREATLY appreciate any help you can provide! Sorry for my poor artwork! Thanks, Meekster
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I cannot make much of your drawing, but my experience has been that a pipe that repeatedly clogs usually does not have enough pitch in it, so the solids do not get adequately washed from the pipe. This problem is even more so with older pipes which are galvanized or cast, as the piping tends to have rust scale on the inside which further increases the rate at which buildup occurs.
  4. wondering
    wondering Member
    Dec 10, 2006
    Alabama
    What kind of detergent do you use? I had the same problem about every 8-12 months. After cleaning the line out 3-4 times I happened to change detergent. I havent had a clog in over 3 years now. I was using Liquid All before.
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    It maybe not the brand of detergent so much as the amount. Lots of us "old timers" use way too much of these newer detergents.
Similar Threads: Bi-yearly washer
Drain Cleaning Dishwasher/Sink/Disposal Jun 2, 2016
Drain Cleaning Double Sink Island w/ Dishwasher Clog Apr 15, 2014
Drain Cleaning The ole washer backup Feb 22, 2014
Drain Cleaning How can I dissolve a clump of de-icing salt in the exit pipe for my clothes washer? Jan 10, 2014
Drain Cleaning Jetting 8" PVC w/ a 3000 psi 4.0 gpm washer? Homeowner questions... Jul 14, 2013
