kf30tn
I'm looking to run a 1,200ft supply line to my house and am researching brands and costs. I have found a brand online and a website called BHS PEX. The cost is much lower but I can't find any information on the brand other than the info given by the listing/selling website. Has anyone heard of or used it? Below are some links and info for reference (sorry if needs to be taken off).
BHS PEX
Badger-pipe.com - https://badger-pipe.com/collections/1-1-2-pex-tubing
OD 1.625
ID 1.244
WALL THICKNESS .19
WEIGHT PER FOOT .35
ASTM 876/877
NOT TO BE INSTALLED IN DIRECT SUNLIGHT
MADE TO ASTM SPECIFICATIONS.
RATED AT 100 PSI AT 180 DEGREES.
RATED AT 80 PSI AT 200 DEGREES.
RATED AT 160 PSI AT 73 DEGREES.
TYPE B PEX IS MADE USING THE SILANE METHOD (WATER BATH).
BHS PEX
OD 1.625
ID 1.244
WALL THICKNESS .19
WEIGHT PER FOOT .35
ASTM 876/877
