Best way to connect 1/2" PEX to 1/4" copper
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by schloske, Feb 26, 2013.
  1. schloske
    schloske New Member
    Feb 26, 2013
    PA
    I am attempting to hook-up a water line from our water filter to a refrigerator. The refrigerator already has a 1/4" copper line connected to the refrigerator that runs about half way to the water filter. The water filter has a 1/2" PEX output (currently to a sink water dispenser). I need to add a tee to that line, then run PEX to connect to the copper. At some point I have to reduce from 1/2 to 1/4. I was originally looking at Sharkbite, but they don't have a 1/2" to 1/4" reducing coupler. Watts quick connect does have a 1/2 to 1/4 reducing coupling, but for some reason, those don't seem as robust as Sharkbite. I don't want a flood. Any recommendations? Any help is much appreciated!
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    Install a shut off valve off of the pex t. This will bring it down to 3/8", then run 3/8" pex to the fridge and connect to the copper with a 3/8"x 1/4" compression coupling.
  4. schloske
    schloske New Member
    Feb 26, 2013
    PA
    Thanks for the reply. I actually already have a shutoff valve installed on for the line feeding the water filter, so that isn't necessary. I am hoping to use primarily push-fit fittings for ease and because I have terrible luck with compression fittings. I'm just having trouble finding the appropriate reducing connections.
  5. jadnashua
    Compression fittings for pex almost always require an internal reinforcement sleeve, but if you do use them, it should be easy to find the proper reduction fitting. Those sleeves are typically SS, but on the smaller sizes, they may be plastic.
Similar Threads: Best connect
Plumbing Forum, Professional & DIY Advice Best way to connect a 2" and 1.5" to a 3" DWHR unit? Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Best Pex Manufacture for Cinch Connections? Feb 7, 2016
Plumbing Forum, Professional & DIY Advice Best way to connect ABS drain kit to brass pipe Jan 19, 2016
Plumbing Forum, Professional & DIY Advice Best way to connect bar sink drain/vent to bathroom rough in Mar 31, 2015
Plumbing Forum, Professional & DIY Advice Best Way to Connect 1/2" PEX to new Kitchenaid Dishwasher? (DIY advice) Mar 16, 2015
