Best Thread Technique / Pipe Dope
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by roback, May 16, 2008.
  1. roback
    roback Member
    Jan 5, 2008
    Los Angeles, California
    Well, I ripped out the reducing valve, per my posts, and got it together and the male extension that threads into the valve is leaking slightly. What a pain. I have to cut the piping and resweat some copper. I used a Hercules product. I usually use a combination of Teflon tape and Slik-Tite. I believed the hype about the Hercules pipe dope with kevlar! Any suggestions to get a water tight seal when screwing a copper thread into brass. What do you guys use, do? Only thing I can think of is that I did not stir up the dope enough prior to using. Maybe it was too thin?
  2. plumb.bob.down
    plumb.bob.down New Member
    May 15, 2008
    I generally use Harvey's TFE Paste on everything.
    It's slow-setting pipe thread compound for threads on any kind of material.
  4. roback
    roback Member
    Jan 5, 2008
    Slow Setting?
    I have noticed that many of the thread pastes say "slow setting." What does that mean? Is it possible that if a connection leaks slightly just after connected and water service turned on, it might stop leaking at some point when the paste sets? I do remember a connection I made a while ago and initially it leaked and then at some point just stopped?
  5. plumb.bob.down
    May 15, 2008
    I don't think that if the constant water pressure is seeping through the threads, it would quit leaking. . .I think the slow-setting means that if it doesn't leak, it will bond almost like teflon tape does over a period of time.
    A lot of times, when we do trap-primers underground on floor drains, we teflon tape 'em, then add the TFE paste.
  6. hj
    leak
    Kevlar? Who needs a bulletproof joint? If a joint is leaking and then stops it is because it corroded, not because the joint compound finally stopped it. Most joint compounds and properly tightening the joint result in tight connections. It is when you start using a formula, such as "hand tight and two extra turns," that you wind up with leaking connections.
  7. Mikebarone
    Mikebarone DIY Senior Member
    Feb 19, 2006
    Phoenix, AZ
    Teflon tape
    This may sound like common knowledge but…make sure when you wrap the male threads with the Teflon tape, that you put in on clockwise, (if your looking at the front of the threaded end section). I always put on a lot of the white tape, (more then I think is needed) and then just be careful that you don’t cross thread it at the start. I have used a pink Teflon tape before, for loose connections, but I haven’t’ seen it at Home Depot lately, (just the white and the yellow gas tape).
    Mike
  8. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    Teflon tape and Slik-Tite is a good combination, it's never failed me. :D
  9. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Best Pipe Thread
    Double Above
  10. roback
    roback Member
    Jan 5, 2008
    Tape and Slik Tite Solved It
    Shoulda known, that switching from my routine would screw things up. No pun intended :) I reassembled with slik tite and plenty o telflon tape and my problem is solved. Now, I can't figure why my solder balled up when putting some of the pipes back together. Not hot enough, water in the pipes?, too much flux, not enough heat etc. etc.? It isn't leaking now, but .....? This was wierd, but it is okay for now, so I don't want to mess with it. Anyone have anything like this happen?
Similar Threads: Best Thread
Plumbing Forum, Professional & DIY Advice Best sealant for connection to in-wall drop ear elbow - Teflon tape or thread sealant Feb 7, 2011
Plumbing Forum, Professional & DIY Advice Best way to remove this faucet drain? Monday at 9:32 AM
Plumbing Forum, Professional & DIY Advice Best Way to Splice Water Off This Sink Jan 5, 2017
Plumbing Forum, Professional & DIY Advice Best Methods for Revealing Pipe Issues Inside Walls? Dec 15, 2016
Plumbing Forum, Professional & DIY Advice Insinkerator, Best garbage disposal? Nov 26, 2016
