Best and Most Efficient Water Heater
Discussion in 'Water Heater Forum, Tanks' started by eaglesclaw121, Sep 22, 2010.
  1. eaglesclaw121
    eaglesclaw121 New Member
    Sep 22, 2010
    Virginia
    We need a new electric water heater, 50 gallon. We call a bunch of different plumbers, and they all "recommend" the ones they carry. A bunch of them recommend the A.O. Smith (but the reviews I've read hate this brand). Others say the GE is not a good brand because it's a "thin tank". Any recommendations? And what warranty should be standard?
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    The one that I had was on 5 minutes out of 7 hours to make up for heat loss. This comes out to a 54 W loss through the insulation so it was 100x(4500 W-54 W)/(4500 W) = 98.8% efficient.
    They're all like that.
    I'd ask how much parts cost, those parts that are most likely to fail.
    You could also search for class action lawsuits against the manufacturers to weed out some candidates.
    There are probably no reasons external to the WH that would cause a WH failure, but do you know why the old one failed?
  4. eaglesclaw121
    Sep 22, 2010
    Virginia
    Our current WH has rusted and the water is starting to leak - it's old and it's overdue anyway
  5. Gsalet
    Gsalet George the Plumber
    Sep 19, 2010
    San Francisco
    There are several questions you need to ask about electric heaters.
    what is more important to you, Fast Hot water, energy conservation, warranty?
    a regular tank type with two elements will give the best recovery of a tank type hot water heater at about 83% efficiency (Cheapest)
    a hybrid tank type will give much better efficiency 230% but takes much longer to recover, unless it uses the backup element (expensive)
    electric tankless 99% efficient need a lot of power most homes don't have enough unless built with tankless in mind
    as far as water heater tanks, they are pretty much the same 6 and 12 year warranties. If you want them to last forever change the anode every two or three years depending on the water conditions and install a expansion tank to help reduce metal fatigue.
    Good Luck
    George
Similar Threads: Best Efficient
Water Heater Forum, Tanks Best 40 gallon gas water heater in Pacific northwest? Nov 23, 2016
Water Heater Forum, Tanks Best Electric Heater? Nov 22, 2016
Water Heater Forum, Tanks Best Tankless Water Heater Brand? Jul 8, 2016
Water Heater Forum, Tanks Question regarding installation best products & pricing on an indirect Brunham Alpin propane boiler Mar 4, 2015
Water Heater Forum, Tanks Smallest/best combination household/radiant floor heat water heater ?? Sep 10, 2013
