Bathtub Install With Mortar
Discussion in 'Shower & Bathtub Forum & Blog' started by JD3263, May 4, 2013.
  1. JD3263
    JD3263 New Member
    Apr 22, 2013
    I'm replacing the bathtub/shower in two bathrooms. I'm to the point where I'm installing the tubs and I plan to use mortar underneath.
    This is the tub I'm using in both bathrooms: Home Depot
    This is the mortar I'm using: Lowes
    Tub 1 is installed and is perfectly level with mortar and a ledger; however, when I stand in the tub, it has a very slight flex to it and you can feel that there is a tiny gap between the tub and the mortar. This is already the second time I've installed it, so I'd hate to make it a third. (I removed the tub and mortar from the first try and did it again because the tub had a little wobble)
    So should I redo it again? I had to redo the plumbing for the drain and everything is lined up perfectly...
    I plan to do Tub 2 this weekend and wanted to confirm a few things before I try...
    1. Is the mortar I'm using a good choice?
    2. What consistency? I've seen people in forums say slushy, but not to the point where it runs. I've seen others say not too dry, but dry enough that you can form a ball that sticks, but won't leave water in your hand.
    3. On Tub 1, I removed the dampening/support/leveling pad that was stuck to the bottom of the tub. I realize this voids the warranty, but I'm not sure if the mortar idea would work with it on there? Do you have any suggestions as to whether I should leave this on or take it off? If leaving it on, what is the process of doing the mortar?
    Thank you,
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    You should not be going for 100% coverage. The mortar should be thick enough so that it will not slump on it's own. If it is too wet, is will shrink too much.
    A 3" tall pile for every square foot of surface area works good if the bottom of the tub has somewhere for the excess to go when setting in the tub.
Similar Threads: Bathtub Install
Shower & Bathtub Forum & Blog Bathtub install on basement slab - plastic below and on top of mortar? Jul 17, 2016
Shower & Bathtub Forum & Blog Is this a properly installed bathtub support. Jul 1, 2015
Shower & Bathtub Forum & Blog Bathtub installation Jun 3, 2014
Shower & Bathtub Forum & Blog Installing a new bathtub, Grohe tub/shower valve. Americast Jan 7, 2014
Shower & Bathtub Forum & Blog install walk in bathtub Dec 15, 2013
