Bathtub enclosure
rascal2
I want to install a bathtub enclosure (that is, sliding glass doors at the front of the tub and a glass return on the short side to the rear wall). I find I can buy decent sliding glass doors at Lowe's or Home Depot for $250 or so. But getting a set with the glass return jumps the price to almost $1000 because the whole thing has to be special ordered. Any suggestions for a lower cost solution?
enclosure
Find a local specialty shop that does bathrooms. They will either have what you want, or can fabricate it very easil, and usually a lot cheaper. For them it is a common task, not a "nuisance" like it is at HD and Lowes.
rascal2
Thanks for the advice.
Local shops wanted around $1500 to fabricate and $500 or so to install a door and what they called a "return". About the same as a special order from Lowe's or Home Depot.
Figured out the best solution is to install a post at the corner of the tub, cover it with cement board, install an in-stock sliding shower door from Lowe's or Home Depot across the long side and then install a sheet of tempered glass in the opening created on the short side of the tub. Cost of the glass is around $150 and the fittings $50.
