bathroom supply leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by findmatt77, May 19, 2008.
  1. findmatt77
    findmatt77 New Member
    May 19, 2008
    I just installed new 1/2" nipples in the supply lines for a bathroom sink, along with new stop vales on each nipple. Now I have 2 leaks:
    One where one of the nipples connects to the elbow joint inside the wall (In this case, the connection between the nipple and the joint is right at the surface of the dry wall). The 2nd is on the other nipple, where it connects to the stop valve. I wrapped each connection with what I'd call 1 1/2 rotations of teflon tape.
    How tight should I have tighten each connection? Today I further tightened each hoping it would fix the leaks. No luck. Any suggestions? Could I have used too little tape? For the nipple/elbow leak, I suspected it could be the old pipe in the wall. But the nipple/stop valve leak is puzzling because it's a new nipple and new valve.
    I'd be grateful for any suggestions.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    The tape should be fine, but many folks on here will recommend that you use tape AND a light brush of pipe joint compound.
    Are we talking about a brass nipple, in a cast fitting in the wall, and a chrome plated brass valve? Then each fitting should be as tight as possible by hand, then 1½ to 3½ turnns by wrench. You have to "feel" it to some extent, but it needs to be quite snug.
  4. Ian Gills
    Jul 24, 2007
    USA
    If you mess the teflon up, it will leak. You need to get it nice and smooth. Redo the Teflon carefully, use pipe dope on top of that and try again. Be gentle when you first start screwing on to the tape. Try not to damage it. You want to minimze the threads cutting it.
  5. findmatt77
    May 19, 2008
    Thanks for the replies.
    Jimbo: You're correct about the materials except for the nipple: it's galvanized steel.
    I've never used pipe joint compound/dope... I'll go buy some. It just brushes on?
    Does it matter if the stop valves are pointing up? If so, how do I orchestrate it so that at their tightest point, they're still facing up?
  6. DuWayne
    DuWayne New Member
    May 19, 2008
    I have struggled with leaky threads on a lot of occasions. I have found that after a certain point, tightening it further is just going to make matters worse.
    I have found that when tying into old, dope can make the difference. I prefer to use the compound that is compatible with ABS and PVC, but that's because I'm a handyman and deal with a lot of plumbing leaks in all sorts of materials.
    It just brushes on with the brush that's attached to the cap. It helps if you leave the very end of the thread clear to help line up the threads to avoid cross threading. The stuff is really thick and can get rather messy - have a damp rag to wipe off the excess. That said, don't be afraid to slop it on, it wipes clean easy enough.
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Whoa!
    What do you have for pipes in the wall? Are they galvanized as well?
  8. findmatt77
    May 19, 2008
    DuWayne: Thanks for the info, I'll try reconnecting using more teflon tape. If that doesn't work, I'll add a little dope.
    You got it Redwood... 1948 duplex: galvanized steel in the walls.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    okay proceed!
    I just wanted to make sure you wern't mixing it with copper.
  10. findmatt77
    May 19, 2008
    For closure's sake, and anyone else who's reading this and plagued by a similar problem, I solved it with about 3 rotations of teflon tape(maybe 4) and a little smear of pipe joint compound(aka pipe dope). I tightened each connection really snuggly, but didn't hunker down on it. I think Jimbo's correct when he says you have to use some feeling when you tighten it.
    Thanks so much for all the valuable input from board members here.
Similar Threads: bathroom supply
Plumbing Forum, Professional & DIY Advice Moving bathroom sink water supply lines Mar 14, 2017
Plumbing Forum, Professional & DIY Advice Off center water supply line for bathroom faucet Feb 15, 2016
Plumbing Forum, Professional & DIY Advice Bathroom Faucet Supply Line and Valve Size? Jan 16, 2016
Plumbing Forum, Professional & DIY Advice Bends in Bathroom Faucet Supply Line Jul 8, 2015
Plumbing Forum, Professional & DIY Advice Bathroom drain and supply Lines Jun 22, 2014
