I am finishing a 10x10 basement bathroom and have extended from the furnace trunk a 6" branch duct supplying heat to the bathroom. However, I have considered supplemental electric radiant heat in the floor or a Cadet 1000 Watt in-wall electric heater operated via a thermostat.
My concern with the mat heat under tile is that unless you leave it on, it will take a while to heat up and if you're just using the toilet then what's the point. If you're going to shower, then it is more helpful.
The in-wall heater sounds like a good idea, they are very aesthetically pleasing and the manufacturer claims it provides heat very quickly.
My plan is also to lay Duraceramic tile. In my experience, this type of tile is not nearly as cold on a slab as compared to clay or ceramic tile.
Does anyone have an opinion whether or not supplemental heat in this 100ft sq. area is likely needed?
Thank you!
Thank you!
