Bathroom floor waterproofing options (and repairs)
Ameds613
Ontario
Part of a bathroom remodel, I am removing an old prefab shower enclosure and replacing it with a new one. I am also replacing the tile floors.
I noticed some water damage at both corners of the old shower base. I have 2 questions for this community of expert diy'ers.
1- What are my options for waterproofing the subfloor before laying my new tile? Am I limited to only using an uncoupling membrane like Ditra? I am trying to avoid increasing the height of the floors, my bathroom floor is already higher than the adjacent room. From what I've read, I don't think I can apply a roll-on membrane directly to OSB or Plywood subfloor. Any input would be helpful.
2- I am inclined to rip out some of the water damaged framing and replacing with new lumber. Is this overkill or a good idea? If so, I am puzzled on how to remove and replace the bottom plate with the electrical cable coming through it.
John Gayewski
Iowa
Are you planning to tile again? Explain how you plan to do that. What other layers will you be installing?
If you're just looking to waterproof OSB or plywood you can use tar paper or felt as it's also known and then a blackjack tar like product to seal where it overlaps and the corners.
Ameds613
Ontario
the subfloor is 2 layers of 5/8" plywood. I'll be layer new tile over it.
If using a membrane is my only option, should I lay the membrane down on the whole floor, even under the fibreglass shower pan? Or should I just start it from the pan and put some sealant in the gap?
